Pre 84 Trucks 1st gen pickups
lift problems
Old Nov 1, 2008 | 05:52 PM
aadown1214's Avatar
Exclamation lift problems
hey guys, was installing a lift today(springs all the way around) and had some occurences........ The rear springs went on fine, however when we let the jacks down the springs pulled the rear shackles to some wierd places. Instead of angled straight up and down or to the rear, they are pulled forward, almost like the springs are too short? Still in the process of the front. Any support on the rear springs would be relieving.
Old Nov 1, 2008 | 05:58 PM
waskillywabbit's Avatar
Compare you old springs to your new in length etc.
Type of springs?
Pictures woudl be great as well.
Old Nov 1, 2008 | 06:02 PM
aadown1214's Avatar
The lift is from rough country suspensions out of tennessee. Put their kit on my ford bronco when i had it, and it was great. So far this kit is sucking wind.
Old Nov 1, 2008 | 06:10 PM
Jeenyus04's Avatar
did you put the springs on backwards? or the fronts in the rear?
Old Nov 1, 2008 | 06:18 PM
aadown1214's Avatar
springs came with attached shims, sort of difficult to install backwards. But we looked at it anyways, and they're on right. It just puts the shackles in the back in a position that will make it ride like a two horse buggy.
Old Nov 1, 2008 | 06:20 PM
aadown1214's Avatar
For Wabbit: Springs are pretty much same length, but arch is difference between night and day
Old Nov 1, 2008 | 06:30 PM
Originally Posted by aadown1214
...rough country suspensions...
That explains your problem right there. You would have been better off with some blocks IMO.
Old Nov 1, 2008 | 07:47 PM
aadown1214's Avatar
Thanks for that, any advice? Should I be that concerned about the shackle position or just see what happens when I drive/wheel it? And the front......ever lift one? Steering/axle wrap bar...anything that I should be aware of? Be easy, I'm a converted Ford guy.
Old Nov 1, 2008 | 07:50 PM
They will probably settle but if your shackle is pushed forward...it doesn't sound good. Driving it will be a harsh ride I imagine. Wheeling it will be a nightmare. Get a refund and make a trip to Alabama and lets put you on a real lift from WabFab.
Old Nov 1, 2008 | 08:02 PM
aadown1214's Avatar
I might be in jail. If push come to shove, I'll feed this junk they call a lift back to this company. Been looking at old man emu, or perhaps allpro if I hit the lottery. What else do you make?
Old Nov 1, 2008 | 08:04 PM
I got all sorts of toys...check out the website...might be a bit extreme for your tastes or budget...but what you got won't make you happy.
Old Nov 2, 2008 | 07:28 AM
refried's Avatar
Are you sure you don't have the fronts on the rear? many springs are labled "front" only to show direction for instalation not position on vehicle. Front springs should be a little shorter than the rears.
Old Nov 2, 2008 | 12:26 PM
nico's Avatar
Check this thread - the guy did a Rough Country suspension successfully. Maybe he can give you some install/setup tips.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
