Pre 84 Trucks 1st gen pickups
1st gen high steer
Old Sep 29, 2008 | 03:58 PM
4x4YOTA's Avatar
1st gen high steer
ok so I am getting ready to put high steer on my 83 and I am trying to figure out how/where and what angle to mount the IFS box I have seen many different ways but which one is the easiest/most effective?
-Im planning on about 4" of lift! (trail-gear 3" front springs/shackle/drop hanger)
-the axle will go forward about 1-1.5"!
-so what is the best way to mount it? (this is me DD/wheeler)
-what pit-man arm do I need drop or flat?
-how far forward?
!!!pics would help out a lot please!!!
Old Sep 29, 2008 | 04:07 PM
mrtejman's Avatar
I did Hi-Steer on my '83 and I used the drop Pitman arm. Make sure the IFS box is as far forward as possible, you may have to bend the body panel a little. I actually used one of the stock steering box bolts in the stock hole to mount my IFS box.
Old Sep 29, 2008 | 04:18 PM
4x4YOTA's Avatar
any pics please?
Old Sep 29, 2008 | 04:57 PM
Island_Yota's Avatar
Theres how mines mounted,(it wasnt quite finished in the pic) As you can see I had to cut the inner fender. It works fine like that, I pretty much put it on an angle so the steering shaft was pointing strait to the shaft on the box, Next time I want to mount it higher up, less of an angle and slightly farther forward, its as far forward as I could without cutting the rad support. If I mounted it any higher the pitman would hit the frame right near the splines on the steering box because the TG drop pitman is so thick.
Old Sep 29, 2008 | 08:29 PM
peckm888's Avatar
here is a few pics that helped me choose
Old Dec 12, 2008 | 08:35 AM
small town BIG TOYS's Avatar
Thanks for the pics!
Old Dec 12, 2008 | 01:25 PM
Al's Chop Shop's Avatar
i would mount your springs and hi-steer first. then you can be sure to get the correct geometry, and to fit your drag link as parallel to the tie rod as possible.
Al
Old Dec 12, 2008 | 03:23 PM
95yoda's Avatar
Could I ask a quick manual steering question in your thread 4x4yota...
what causes a "swishing" sound in my manual non power steering when I turn the wheel? is that normal? sounds like something that needs lube?
Old Dec 12, 2008 | 03:47 PM
dropzone's Avatar
Fossilized
Al
yes, good advice. especially since you won't have clearance for the tie rods until the springs are mounted anyway.
I screwed up when I did mine ...it's one of the things getting fixed...
use a 3/4" hole saw instead of a 3/4" drill bit, it will be faster...
Old Dec 12, 2008 | 05:45 PM
4x4YOTA's Avatar
will high steer work with any 3" spring or just the brand names TG, Marlin, All Pro... or can I use Pro comp 3" springs
Jun 1, 2021 01:51 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
