Pre 84 Trucks 1st gen pickups
loosing coolant
Old Nov 26, 2008 | 07:34 PM
ktown808's Avatar
loosing coolant
k i have a 1982 22r with about 140,xxx and this thing pretty much drinks the coolant haha. so ill fill it up and i say about 4-5 days later this thing is pretty low but all the coolant is going into the coolant reservoir so idk whats up, first yota but this gettin kinda irritating so any help is appriciated thanks aloha
Old Nov 26, 2008 | 08:03 PM
small town BIG TOYS's Avatar
Check your rad cap.
Old Nov 26, 2008 | 08:18 PM
9am4x4's Avatar
check coolant lines going to block, heater core..etc from radiator, make sure that theres no pinholes or cracks, even around hose clamps..
also sometimes you need a rad cap that has a de-pressure valve on it..was the case in my '80..would overheat and boil all coolant out into overflow until i changed it.
also check that you have the right temp. thermostat..the lower temp the better
Old Nov 27, 2008 | 06:23 AM
refried's Avatar
check your cap
A lower temp thermostat is NOT better, most engines run most efficiently at around 200* and wil use a thermostat that will fully open at 185 or 195*. When you run a lower temp stat the engine can't burn all the fuel as effently and a good portion of it goes out the exaust. When EFI motors first became popular we would run a 160* stat to make the ecm deliver more fuel thinking the engine hasn't warmed up yet, it really didn't help much and it only made them smoke at idle.
Old Nov 27, 2008 | 10:22 AM
9am4x4's Avatar
hmm..worked in my 20R for some reason..
but that is interesting..
Old Nov 27, 2008 | 03:23 PM
ktown808's Avatar
k thanks ill get a new cap and thermostat my engine never heats up so the guy before me prolly just took it out and yeah the coolant lines are pretty rusted out but i just changed the upper and lower hoses a month ago
ladybugRC
458
Aug 21, 2020 10:41 AM
Davebarbier
Nov 3, 2015 03:28 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
