Pre 84 Trucks 1st gen pickups
Running hot?
Old Nov 25, 2008 | 07:13 PM
small town BIG TOYS's Avatar
Running hot?
My 83 is having a over heating problem. The problem started a little after I had my transmission replaced. (Witch is going out again ) I have replaced the water pump,Thermostat,rad. I have also flushed the coolant out a few times.
The truck has been close to over heating but never got in to the red.
After I replaced the water pump the truck runs a little cooler but it is still running hot.
Thanks.
Old Nov 25, 2008 | 08:25 PM
myyota's Avatar
Take a look at the fan clutch, if its bad your fan won`t kick in to cool things down when needed.
Old Nov 25, 2008 | 10:10 PM
Al's Chop Shop's Avatar
does it overheat at stop lights, at higher speeds.... both?
Al
Old Nov 26, 2008 | 10:40 AM
It runs hotter at stop lights more then just driving. But on hotter days it runs hoter when I am driving. And I checked my fan clutch and it feels like it is working ok. It has a little play but thats it.
Old Nov 26, 2008 | 03:51 PM
Bump and If it helps any the truck started playing this game in mid June.
Old Nov 26, 2008 | 08:01 PM
bump.
Old Nov 26, 2008 | 08:15 PM
881stGenRunner's Avatar
are you losing any coolant?
p.s. get on flashchat
Old Nov 26, 2008 | 09:21 PM
sounds like an air flow problem. start with a new fan clutch, they are cheap.
Al
Old Nov 27, 2008 | 09:11 AM
I will replace the fan clutch I replaced everthing else.
Old Nov 27, 2008 | 12:31 PM
gsb15's Avatar
try and check what the temprature is another way besides the gauge. my freind was having the same problem with the 22r in his celica. we replaced everything in the system and nothing changed. we took a thermometer gun to it and found it to be running at 190. it ended up being the gauge its self was miss reading
Old Nov 28, 2008 | 04:12 PM
I replaced the fan clutch today. And I replaced my rad cap. I will let you all know it fix's my problem.
Old Nov 29, 2008 | 09:58 AM
I fixed the overheating problem. (fan clutch)
But now my engine is dripping coolant .
I just can't win!
the1998sr5
15
Jul 14, 2020 08:35 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
HRDC0R19
Jul 5, 2015 06:43 PM
