Pre 84 Trucks 1st gen pickups
engine id questions
Old Nov 17, 2008 | 03:00 PM
screwcity's Avatar
engine id questions
I guess this should be an intro as well....
Not my first toyota but I always wanted a first generation.
now I have one body is in good shape, but the engine needs a new timing chain. I'll post pics as soon as possible.
I just purchased a '81 toyota pick-up I have a bad timing chain cover. I don't believe that it is the original engine.It is my understanding that the '81 motor had a dual row timing chain and the more rounded valve cover. This is not the case with my motor and I don't want to order the wrong parts. I have a carbed, single row timing chain, and square style valve cover. The serial number on the motor is 1788881. can you use this number to reference what year it is so I can get the correct kits to swap in a new timing chain and head gasket? Any help would be greatly appreciated!!!
thanks in advance!!!
Rio
Old Nov 17, 2008 | 03:09 PM
fdizz's Avatar
im thinking an 85-88 22r
also this is a must to lose the plastic guids..http://www.lceperformance.com/22R-Si...-p/1015035.htm
Old Nov 17, 2008 | 04:22 PM
screwcity's Avatar
I guess that I was under the impression that they were all fuel injected after '85. Is this out of a truck? or what?
I do have the pear shaped ports on the head. I'm just puzzled because there was no mention from the previous owner...about an engine swap.
Rio
Old Nov 17, 2008 | 05:14 PM
fdizz's Avatar
people blow a headgasket on a 22r and just throw it in the gutter and swap in a new one... so even the PO might not have known.
Old Nov 18, 2008 | 01:50 PM
screwcity's Avatar
yeah I suppose so..
I have never owned a pre '84 toyota. I looked in the engine compartment and saw a carbed 22r, the valve cover didn't send up any red flags...it wasn't till I saw a single row timing chain that I realized that something was up.
Any way to tell what this might have come out of?
The Block does say 22r on the smaller boss next to the serial.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
