Torque Specs For 1983 22r Manifold Studs + Nuts
Hi,
Does anyone have the torque specs for the engine studs 83 22re 4x4 for the manifold and the specs for the manifold nuts??
thanks
thanks
don't have an FSM for an '83 but I found this in my '81 FSM...should be close..at least should be pretty close until you get more precise info:
-manifold to head: intake 13-19 ft lbs
exhaust: 29-39 ft lbs
hope this might be what you need, if it was size of the stud or nut size I did not see that info in the manual.
kgcwb44
Jan 29, 2023 10:02 AM
