Pre 84 Trucks 1st gen pickups
Brake issue
Old Oct 14, 2008 | 08:57 AM
secondarychaos's Avatar
Brake issue
Hello,
I took home my 79 yesterday, and after about 5 miles, the brakes slowly began to drag, until they completely stopped the truck. I waited a few minutes, started it again and away it went, until about 5 miles later.
Does anyone know what may be causing this?
Thanks,
Dan
Old Oct 14, 2008 | 09:18 AM
kev's Avatar
kev
brake issue
Originally Posted by secondarychaos
Hello,
Thanks,
Dan
It may be that the emergency brake cable is seized.(rear only) Do all of the brakes lock up ? nAlso check any rubber lines for swelling/bulging, at or around the metal line fittings.
Old Oct 14, 2008 | 10:10 AM
Hard to say if its all four or just the back, it takes a minute or two from first noticing to full stop. I'll check for that.
i'll also look for the swelling.
Old Oct 14, 2008 | 10:30 AM
oldschool4runner's Avatar
This happened on my 81, I ended up replacing the master cylinder because there was some crap in it causing it to stick. It needed to be replaced anyway.
Old Oct 14, 2008 | 10:36 AM
That was my original thought, was master cylinder.
thanks for the responses. hopefully i can get this fixed so i can go wheelin again. lol
Old Oct 14, 2008 | 11:30 AM
dropzone's Avatar
Fossilized
If it is your master cylinder consider upgrading to a 1" bore master cylinder like wab fab, Trail-gear or Marlin sell. About $125 but a good upgrade especially if you are planning on running some bigger tires later on..
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
