Pre 84 Trucks 1st gen pickups
The woes of wiring.....
Old Dec 6, 2008 | 06:13 PM
aadown1214's Avatar
Anybody have the patience for wiring? Im running into a few snags with my latest project. Wiring harness is good, just having a few setbacks. Pulled close to 100ft of wire that some jerk put in wrong/not needed. Now that all the fire hazzard is out of the way, im having a few problems getting things like the blower motor to work again. Diagrams in chiltons and haynes aren't very helpful. Any advice? **all the wire i pulled was NOT factory, it was supplying power to the 4 horns and whatever else was on the truck when i got it.
Old Dec 6, 2008 | 06:17 PM
4banginRunner's Avatar
ugh doing this now to my 79 I feel your pain!
previous owner butched the wiring up real bad
i swapped cabs...now i cant get the heater to work, the rear half of the harness is a nightmare, interior lighting is non-existant, gauges except speedo dont work
i need a FSM lol
Old Dec 6, 2008 | 06:22 PM
aadown1214's Avatar
My wiring isn't quite that bad off, I got lights and gauges, tail lights and all that, but its about damn cold in the north ga mountains so i gotta have heat. Here's the kicker, it worked last week after i pulled out all that crap wiring, and it didn't today. Fuse was good and all that, so i think im in for a ton of fun.
Old Dec 6, 2008 | 07:39 PM
scooper's Avatar
I guess im one of a few who loves wiring. I'm OCD about it tho, I like it to be in a nice tight spot and not just laying anywhere it will fit. What I would do is get a test light or multimeter, find the wiring into the heater and chase it out of the heater, I usually use a multimeter and put it on the sound setting that makes a sound when they contacts touch. Start chasing and following a single wire at a time. It will take some time but it's the best way that I have found. Make sure to look for cut or bare wire spots, and double check all your grounds.
Old Dec 6, 2008 | 08:12 PM
yota8083's Avatar
I had to fix the wiring in my 80 4x4 truck when I got it a few weeks ago. Didnt have power to anything in the cab. Just a process of elimination really to trace the problems out. It wasnt bad to me though, I love wireing and have several years experience with it in vehicles. Hope you figure out the problems you are having. Good luck with it.
Old Dec 6, 2008 | 08:56 PM
dropzone's Avatar
Fossilized
it is nice to run into 25 years of other people's versions of how to fix stuff. everything on my '81 works but I don't know why some of the wiring is pretty well fubared.
here is a link to the wiring diagram from my '81 FSM..they are just pics but it might help you out: Link to Wiring Diagram
Old Dec 7, 2008 | 12:26 PM
Your the man
potatopants
Sep 15, 2015 06:26 AM
tirogers
3.4 Swaps
Mar 24, 2011 10:03 PM
bigt
Oct 28, 2008 05:19 PM
