Pre 84 Trucks 1st gen pickups
leaf springs
Old Sep 10, 2008 | 10:11 PM
4x4YOTA's Avatar
leaf springs
are leaf springs inner change able between a 83 and 84 toyota 4x4 pick up. are they a direct swap or will it not work
Old Sep 10, 2008 | 10:38 PM
dropzone's Avatar
Fossilized
yes, but you might want to double check the eye to eye measurements to make sure that some one has not done a conversion to one of the trucks (like put in 57" in springs)
Old Sep 10, 2008 | 10:40 PM
fillsrunner4's Avatar
was gonna say the same thing. check the eye to eye and if its the same then I dont see why you couldn't change them out
Old Sep 11, 2008 | 04:44 AM
nico's Avatar
If they're stock spring lengths and stock mounts, any year '79 - '85 is interchangeable.
Old Sep 12, 2008 | 02:58 PM
brooklee1000's Avatar
helper spring--get an old used coil from another vehicle, and jury rig it between your leaf and the frame. www.gearinstalls.com has a good write up about this, and it works well! Mine has that setup, cost me $40 for the coils from a suspension shop that lowers cars and trucks. Watch the spring rate though. To light, you gain nothing, to heavy, rides like a brick.
Old Sep 12, 2008 | 07:34 PM
4x4YOTA's Avatar
I am actually looking to trade lifts with a friend I have a 7" and he has 3 and he wants to go higher but I want lower so we were thinking of trading only problem is I have an 83 4x4 he has a 84 4x4
Old Sep 12, 2008 | 08:04 PM
nico's Avatar
You can trade straight across, unless his springs (or yours) are longer than stock length. In other words, if both your springs use the stock spring mounts, then they are completely interchangeable.
Front springs have a left side and right side, typically, so don't mix those up. Rears are identical L + R.
Old Sep 13, 2008 | 02:14 PM
4x4YOTA's Avatar
ok thanks than it sounds like it will work thanks guys!!!
Old Sep 13, 2008 | 02:58 PM
4Crawler's Avatar
Only difference you may see is the rear spring forward spring eye and bushing being different between the two years. In '83 you had a 30mm ID eye and a bushing for an 18mm bolt. In '84 you have a 40mm ID eye and a bushing for a 14mm bolt:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ16
Could easily put in a set of new poly bushings and sleeve the one for 14mm and leave the other one at 18mm.
Old Sep 13, 2008 | 03:42 PM
algranger's Avatar
Originally Posted by nico
You can trade straight across, unless his springs (or yours) are longer than stock length. In other words, if both your springs use the stock spring perches, then they are completely interchangeable.
i dont mean to sound like an ass but its the spring hanger and shackle mounts he should be worried about, not the perch, the perch is the platform welded tothe axle forthe springs to 'perch' on
Old Sep 13, 2008 | 04:35 PM
nico's Avatar
Okay, mounts.
Old Sep 14, 2008 | 11:30 AM
4x4YOTA's Avatar
ok see this is what I needed to know...
how hard is it to swap out bushings?
could I just pull the sleeve out of his spring bushings and but it back in mine when they go on his truck?
Old Sep 14, 2008 | 11:37 AM
4Crawler's Avatar
The 30mm bushings are simple split types, come out easy. The 40mm ones typically are pressed in and need to be pressed out and the sleeves are bonded to the rubber of the bushing. With aftermarket poly bushings, they are split design and easy to replace.
Old Sep 14, 2008 | 11:39 AM
4x4YOTA's Avatar
well we both have the after market poly bushings in our springs!
so will that make it easier?
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
