Pre 84 Trucks 1st gen pickups
20r head removal
Old Sep 15, 2008 | 03:53 PM
78littlechief's Avatar
20r head removal
Hey I am a new owner of a 78 toyota pickup (actually motorhome called the little chief). I got a great deal on it but partly due to a blown head gasket. I've already torn down most of the parts to get to the head but I can't budge the head from the block. As far as I can tell i've removed all the bolts but there are 2 allen key slots on top under where the cam was. Do these need to be loosened or can they even be loosened? I've never worked on a toyota before so its' different than anything i've seen. PLEASE HELP!
Old Sep 15, 2008 | 04:45 PM
slacker's Avatar
no .. those big allen bolts are coolant passages ..
BUT .. under the distributor (you need to pull the distributor) is a hidden bolt into the timing cover ..
12MM head ..
Old Sep 16, 2008 | 05:55 AM
83's Avatar
83
Yup, hidden in a little pool of oil at the very front of the head there's a bolt. Even after that, though, it should be a little tough. I can't remember where but once you know that you've got all the bolts out, you can pry against some areas of the head. Just make sure not to damage anything.
80Truck
Oct 12, 2025 07:25 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
PopsDad1
Jul 30, 2015 02:21 PM
calderp
Jul 27, 2015 09:58 AM
