Anybody got an FSM?
Anybody got an FSM?
I'm looking for probably two pages out of it (1983) which detail the instrument cluster plug-ins. I'm doing the SR5 cluster swap, and I've got a schematic of what wire number (or I guess plug-in spot number..) controls what cluster function on SR5 compared to non-SR5, so that I can move them around. So I have the numbers and what they do, but not how the numbers correspond to the actual wires. All I have is an 85 FSM, and I don't trust that they're the same. There should be two pages in Body Electrical, Instruments and Sender Gauges which shows "combination meter & gauge with tacometer" , and "without tachometer". I'd love for someone to post or PM me these two schematics so I can get my SR5 cluster working! Right now my fuel gauge sometimes works, the spedometer works, and my right blinker shows up. That's it. No lights when my headlights are on, no temp gauge etc. So here's what I've got, and what I need is where these numbers are on the plug-ins:
SR5 non-SR5 wire color function
1 ---- 1 --- GY --- Right turn signal indicator
3 ---- 3 --- BR (B BR) ---Speed sensor (-) ground
4 ---- 6 --- GL --- Speed sensor (+)
7 ---- 23 --- YG --- Water temp gauge
8 ---- 9 --- RW --- Panel lights (+)
9 ---- 15 --- YR --- Fuel Gauge
10 ---- 12 --- Y --- Ignition switched power
11 ---- 21 --- YB --- Oil Pressure switch (idiot light)
12 ---- 22 --- YW --- Charge (idiot light)
13 ---- 14 --- WB --- Ground
14 ---- ---Tach input - must be wired to igniter
---yellow
15 ---- 17 --- GB --- Left turn signal indicator
16 ---- 16 --- RB --- Panel lights (-)
17
18
19 ---- 11 --- G --- 4WD
20
21 ---- 19 --- BY --- Seat belt
22
23 ---- 13 --- RG --- High Beam
24 ---- 20 --- GW --- Brake
Thanks for your help!!!
---yellow
17
18
20
22
Thank you. Unfortunately I don't think it will work.. my plug-ins look like the one on top, and yours look like the one on the bottom. Mine may actually be close to the 85 I have the FSM for, but it shows something like 32 wires, instead of the 24 my first post shows. Hopefully somebody's got an '83!
Hey thanks! Let me know if you get it, since I would like to have those diagrams, but I got it over the weekend! The 85 diagrams gave me a good enough idea of how it's laid out. The only difference is that we have 23 or 24 wire slots in our plugs, instead of the 32 or whatever in 85. With that list I posted it actually made pretty good sense once I got in there and looked around. Now everything works.......except my odometer! Doh! It was working before....
accuracy
09-20-2015 07:44 PM
Boomer8404
09-20-2015 06:15 PM
