View Full Version : Pre 84 Trucks
- ZUK mod on a 1st gen shortbed! Pics
- Introducing myself as a NOOB with Toyotas
- Pics of 81 alternator
- Past Yotas Present Parts
- Engine Coolant Disappearing
- 83 1st gen grillse to 88 2nd gen
- 16 gallon fuel gauge vs 13 gallon fuel gauge IS THERE A DIFFERENCE??
- Shackle angle issue with 3" RC lift on rear
- Brake Squeal..
- OIl Leak
- Whats the best Carb
- 1980 4x4 Suspension
- Rod knock, 22re engine swap time? 79'
- For Tall Owners of 1st Gens
- 76 chinook working in the rain
- wheeling on 31's whats possible?
- ID MY header..and make a few suggestions please.
- 31" tires new motor and gas mileage and power problem problems help!
- 3rz stock dash
- Why does the vacuum advance have two vacuum lines?
- stalling intermittently like a switch
- great info on hi-lux history
- 76 chinook mostly I'm just excited about this project
- 82 22r EXPLOSION on startup. Whats up??
- Washed and waxed the Toyota today!
- 1976 truck has to pass california smog
- Tranny swap
- Pitman arm/draglink issue?
- 78' stock, high speed shake
- Power steering swap shaft length
- L50 tale shaft ?
- 1980 4x4 4spd to 5spd swap
- white smoke after rebuild
- Possible Wolverine Bed??
- !st Gen Bucket Seats
- 82 hilux build...slow
- 20R Exhaust Manifold: HELP!
- Idling Issues
- Death Shakes
- Replacement Leaf Spring Pins
- 22R Oil Pressure and Volt Meter install help
- Forward shift conversion
- lower and mid throttle problems 20/22 hybrid
- Toyota "Big Red Wagon"???
- 22r head problems
- 1983 Pickup Original Documents
- Tool Box Ideas
- Water pump removal help
- 22r crank size
- New Lift...New vibration
- front main oil seal?
- shock flange replacement... do the make em?
- lights under truck... kinda cool
- weber 32/36 vacuum problem
- Which Weber- 32/36 or 38?
- LOW LOW Oil Pressure after warm, Opinions please
- How many rear leafs can I remove?
- Getting Exhaust done Need recommendation
- Gear decision...... 4.56 or 4.88?
- '82 possible vacuum issues?
- Poser Flex Pics Testing The 63's & RUF
- 1980 4x4 longbed
- Cab Removal, how's it done?
- popped my mud cherry today.
- Oil Magic Trick
- front leafs droop more
- 1980 2WD vs 4x4 valance/bumper
- Are our trucks good "Doomsday Trucks"??
- 3" Rough County Lift on 1983 Pickup
- Factory posi?
- anyone have Carb Rebuild experience?
- stock carb to weber question
- Gear ratio gas mileage?? lock vs. free diff opinions needed
- HELP - '78 carb part
- 1979 Truck that has been sitting 20 years!
- 78 Toyota Pickup/Chinook
- Eating Fuel Pumps.
- heater question
- Custom Bumper Mounting
- time for a new brake master cyl?
- high idle when first starting 81' hilux/camper shell?
- what is my carb cfm?
- seats?
- Chevy 63" Question... yes another one.
- Body swap VSS question
- 81 22R Do I put the head gasket on dry?
- 63"s and ruf
- Too many vacuum lines!
- Drain Plugs... They're all stuck
- coolant pressure issue?
- Epoxy Primer
- Steering Arm
- Oil and Amp Gauge
- Opinions/advice needed on my 83 Pickup
- 1st gen swap
- Which 5-speed for my 80?
- carb power valve-how tight?
- 1981 toyota 4x4 20r22r hybrid
- 73 20R go into 83?
- L to G series shifter?
- 79 sr5 longbed 2wd fuel issues
- Custom dash?
- Cluster swap from different rigs
- check out my monster yota
- Source for 83 Steering Column Cover
- Is there 5th gear?
- Junkyard Motor please help!!
- Strange Brake Pedal Feeling...
- Dry oil filter???
- BAD driveshaft vibration
- my '83 p/u
- Electronic choke setup?
- 22r Aisin Carb Choke location???
- 1983 2WD Pickup Headlight Upgrade?
- 36 or 28/36 Weber Gaskets?
- 1983 Build/restore thread
- Parked for 3 weeks now won't start.
- carb issue
- '80 Dash, no tach, now tach. Other dash light upgrades?
- 1983 hilux
- I hooked up the return line on a weber, what can it hurt
- 83' HILUX "Street Runner" Restore Project
- How did this Happen??
- 1983 SR5 Hilux Restore - "Project Street Runner"
- Painted! 79'
- 81 22r mini backfire issue?
- I can't make an album, so I'll make a thread.
- Another 20r with carb Problem
- 1983 body parts/ support bracket diagram needed!
- catalytic converter question
- no one will smog my truck
- smoked a deer ....
- Body Panel Website - Including Bed parts
- 20R Vacuum line size/length
- whirring sound from 20r engine
- Trouble with fuel line leak!
- My Toyota
- 1980 pickup bodylift
- recessed winch
- New to me '81
- Bed Sheet Metal
- My new......old Toy!!!
- No body mounts.... :(
- throttle pedal
- decking 22r
- clutch/brake pedal bushings
- 63's & RUF almost done
- Bobbing long bed
- Sucking air??
- low on power please help
- Manifold too hot?
- Installed new water pump, doesn't want to start?
- 83 pickup WONT START??
- Power steering
- stock tach not working
- 20r head on 22r block
- '81 Pickup Bed bolts
- Pics of your interior? I need options!
- temperature gauge broke?
- 79 Engine Issues-blown ring? headgasket?
- 82 sr5
- transmission and slave cylinder 22r
- carb modifications on 1980 20r
- carb problem somwhat fixed
- Help with AC connection '79-'83
- 16x8 with 4" backspacing on 33x10.50 boggers, will it work???
- 83 22R Cold Start Takes Forever
- Accel 300+ IG box-->No spark after accel 300 install
- unique charge light issue on 82 22R
- 81 4x4 22r Blowing oil from valve cover.........
- 83 Tachometer
- 83 22r idles sometimes
- Oil pressure weird when starting cold
- weber carb and de smog questions, help me decide
- 82 4x4 volt meter showing 9 volts
- R1FA Help
- Carb Linkage
- toyota 22r intake bolts
- Ruff Country 4" Suspension Lift 1983 Pickup
- My 82 vibrates like its in the spin cycle
- 82 weber 32/32 DGEV electric choke to manual conversion - need pics
- RUF advice for my 81
- 78 Toyota w/20R or 74 Toyota w/18RC
- Headlight upgrade for an '81?
- Horrible Mileage help!!!
- 83 4x4 loud whining in 1st,2nd& 3rd
- zero oil pressure
- 82 sr-5 charging nightmare
- 1982 Fuel pump leaking 22R
- Losing water
- gear ratio on my 82
- 83 Won't Start, No Accessories, Charged Battery, HELP
- Warn Brush Guard/winch mount
- I'm new here and from holland
- Weber & Offenhauser Questions
- lower SR5 gauges will not bolt on. Why?
- 82 toyota, wanting to swap the front end for a 85 i have fenders hood and all
- Head Questions? Swap 22r 20r etc
- Throwout bearing issues...
- Budbuilt or Generic Cross-member Questions
- 79-83 Radio Bezel
- 1980 Long bed build
- 82 hi lux stock gears??
- 1981 Toyota 4x4 New to Me
- 22r block 20r head, having starting issues
- 2wd 4wd cab and frame compatibility??
- front breaks are sticking
- 82 hi lux build.
- Heater core hose confusion.
- Weber 32/36 on 22R oil in air filter PCV?
- How to tell what Tranny you have?
- Just bought an '81. Now... swapping axles
- What to make of this spare L43....
- Frame Issues
- Ideas to stop a theif
- Finally got a 1st gen!
- 82 yota width??
- 82 4x4 pickup first timer
- another weber carb concern
- Heater Not blowing much
- Why wouldnt my first and 2nd plugs be firing?
- The low down on NW Offroad suspension kits
- Does you 1st gen take awhile to warm up?
- Best method for gear reduction?
- steering and brake issue?
- G 54 cross member fix my way..
- Installing a crane HI 6 s ignition on 82 4x4
- charge light on and wont idle
- Window off track in '79. Any ideas?
- New toyota owner
- Stock Bumper
- swapping L43 to R151F (or W56 etc)
- help I.D. my transmission? (pics)
- LC timing chain question
- Need some info on guages
- What is this code?
- Weber 32/36 issues....
- Need Help.....Horn stopped working
- New owner from Union City, California!
- Flat bed
- 1980 pickup Oil idiot light flickering.
- What are people putting for leaf springs on a 1983 pickup
- 78 Toyota manifold question
- LIMITED SLIP for my 82???
- crazy rattling noise
- Im getting sick of swapping motors..
- Carb help!!!!
- 82 Window Regulators
- Battery
- First things to go......
