Pre 84 Trucks 1st gen pickups
front main oil seal?
Old Mar 11, 2012 | 05:15 PM
uglymudder's Avatar
She started leaking today, looks like from right behind the crank pulley. Called local parts shop and ordered a front main seal. Has anyone else done this already? Couldn't find a thread pertaining to this topic...do I just pull the crank pulley, and find the seal right behind it? How do I get it out? She's an 81 sr5 22r. Thanks.
Old Mar 11, 2012 | 05:34 PM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old Mar 11, 2012 | 06:04 PM
Teuf's Avatar
This may help, rethink oil seal thickness.https://www.yotatech.com/forums/f114...81-2wd-126295/
Old Mar 11, 2012 | 06:13 PM
Truckstarr's Avatar
I recently did mine on an 86 22r. Definitely get the seal from the1994 (i think). Its thinner 7mm vs 11mm. Set the seal like 1 mm deep. This way the worn groove on the shaft won't line up with the seal. Worked great.
Old Mar 11, 2012 | 07:21 PM
uglymudder's Avatar
Ahhhhhhhh..........thanks for the links..........I don't always get accurate results from searches bc I do them from my phone. It seems that everyone suggests using a later model seal, 94/95ish, due to being thinner and thus easier to position out of the existing groove worn in the pulley hub. I'll give it a shot...btw, I know its not the "proper" way, but can I put my socket on the crank pulley bolt and hit the starter to loosen it? Did that with other trucks with good results.
Old Mar 11, 2012 | 07:25 PM
Truckstarr's Avatar
Definitely!
andrewtexas123
Jul 14, 2015 04:29 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Gamble_STi
Jul 7, 2015 07:54 PM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
