Pre 84 Trucks 1st gen pickups
81 22r mini backfire issue?
Old Feb 3, 2012 | 05:31 PM
igotit's Avatar
Exclamation 81 22r mini backfire issue?
i recently installed a 81 22r into my 82,engine runs great.
has weber carb installed.
new plugs,new wires,cap/rotor...ec.
havent checked timming yet.
fires up in less than a revolution without hessitation.
slight hessitation when cold (sluggish on low end rpm),but once warmed up....shes good to go.
i already sprayed vacume lines with carb cleaner while running,sprayed around the intake/carb aswell...no change in idle.
sometimes on startup i get a faint gas smell for a few seconds,sometimes i dont.
after i drive around a few miles,i shut engine off in idle...bout 1 second after engine dies...i get a ....sneeze from the tail pipe,a mini backfire.its very quiet,but still.
what could be causing this....maybe choke hanging up,or not set right?
maybe a few degrees off on timing?
lend me your opinions please!
thanx
Old Feb 4, 2012 | 08:35 PM
igotit's Avatar
it was the choke sticking,when i give her full throttle the choke engauges and sticks.
without the choke sticking....the weber needs a tune up.
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
cars-guy
Jul 11, 2015 07:51 PM
Edionne13
Jul 9, 2015 01:59 PM
