Pre 84 Trucks 1st gen pickups
22r crank size
Old Mar 12, 2012 | 03:36 PM
YotaBoy83's Avatar
22r crank size
Okay so I am rebuilding a motor and I'm trying to find what size bearings I have or if I could just measure the crank journals with a dial caliper. Does any one know what the stock size of the crank journals are?
The bearings have a sign like (lh) and say H30S
0170A
Please help
Old Mar 12, 2012 | 03:42 PM
BMcEL's Avatar
Not going to grind the crank and match the bearings accordingly?
Old Mar 12, 2012 | 03:55 PM
YotaBoy83's Avatar
well its just getting a basic rebuild and the bearings in it still had easily had under 50k on them I am fairly sure the motor has be gone through before be I just wanted to be sure. Plus the crank is in perfect condition not even the slightest scratch.
Old Mar 12, 2012 | 04:37 PM
slacker's Avatar
easiest way is to plastiguage to see if the clearances are correct
Old Mar 12, 2012 | 05:06 PM
YotaBoy83's Avatar
I will when I get the bearings
Old Mar 12, 2012 | 05:37 PM
xxxtreme22r's Avatar
Plasigauge won't tell you if you have an out of round oblonged journals. I highly suggest you have a machine shop look at both the crank and the block.
Why are you tearing apart the motor after only 50k?
Old Mar 12, 2012 | 06:18 PM
YotaBoy83's Avatar
Well the motor was a junkyard motor and I wanted to tear it apart to be sure it was good. Also I took dial calipers to it all the way around each journal and the measurement didn't change.
I found the measurements of the standard journals and I was with in thousands of the standard
Old Mar 12, 2012 | 09:57 PM
YotaBoy83's Avatar
Never mind I measured bearing thickness, journals, bore and they're all STD and all with in round. Now I just need a speedy sleeve on the rear end of the crank
sandyota
Feb 4, 2021 11:16 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
TDonkey
Jul 26, 2015 10:14 AM
