Pre 84 Trucks 1st gen pickups
Another 20r with carb Problem
Old Feb 3, 2012 | 12:42 PM
DES_YODA's Avatar
I have a 20r with water choke, I adjusted it and now the engine is staying on... But when at idle it jumps and stutters just a bit like very small amount... I think I set the float too high... Could that be the problem? Or maybe the fuel mix is set wrong? I want to make sure its at it's best running state before I take it to emissions...
Any info would be awesome
If you need video or more info please just ask
Thx for reading
Old Feb 9, 2012 | 03:19 PM
MercuryMan's Avatar
Yea more info needed. Do you mean the engine is 'dieseling' or continuing to run after you shut it down?
Float set too high would cause over-rich mixture which could be a contributing factor. There is also a solenoid that shunts the flow of fuel from the pump without ignition power-if it's not getting voltage that might be your issue. You need a vacuum gauge at the very least and a tach gauge (good to have) to set your mix correctly. You can do a plug chop to see where your mix is-drive under load around 4k rpm's then kill the ignition and stop and look at the inner most part of your plug's insulators-dark and oily looking=too rich. They should be a brownish color and mostly dry.
Why were you adjusting the carb-did you clean it? What have you recently done.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
skoti89
Sep 11, 2015 07:46 AM
calderp
Jul 27, 2015 09:58 AM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
