Pre 84 Trucks 1st gen pickups
36 or 28/36 Weber Gaskets?
Old Feb 5, 2012 | 10:45 PM
DLK808's Avatar
Anyone know where I can find gaskets for the DCD webers in the US or anyone know info on them? I tried googling sites that sell the gaskets but there all european based and I live in Hawaii. It would take forever to reach me.
Old Feb 6, 2012 | 03:51 AM
80banana's Avatar
Pierce Manifolds out of Gilroy, CA (www.piercemanifolds.com) can probably get you the gaskets you need. They carry a lot of DCD parts. If you're just looking for the carb flange gasket, you could make those from a roll of thick gasket paper.
Are you currently running this carb on your truck? If so, I'd be interested in seeing your setup. The DCD is a great carb.
Old Feb 6, 2012 | 07:36 PM
DLK808's Avatar
Thanks! Truth is, i dont know anything about carbs. All my knowledge is based on google, this site and a service manual. I just know that its leaking and letting fumes into the cab. The truck kicks when i shut it off, so i leave it in first and let the clutch out to stop it. It doesn't look like a 32/36 to me and when i came accross the 36dcd on the internet i pretty much told myself it was the same. Thats just me not knowing s***. Haha! So any info helps alot and i appreciate anyones time!
Old Feb 6, 2012 | 07:38 PM
DLK808's Avatar
Old Feb 10, 2012 | 10:42 AM
80banana's Avatar
With Webers, there should be a number either on the side of the carb mounting flange or on the side of the bowl. That should tell you the model you have and what rebuild kit you need. What you probably have is a DGEV, which is a Weber DGV with an electric choke.
I would recommend getting a Haynes Weber carb book, a full rebuild kit and some carb cleaner and thoroughly go through the carb. Be sure to degrease it before you tear it down.
Old Feb 10, 2012 | 12:10 PM
JonnyBoy's Avatar
That's no DGEV, cause it doesn't look anything like mine. I would probably get ahold of Pierce manifolds and maybe send them those pictures or something, cause I'm not sure what that is.
kazuya2416
Apr 5, 2024 02:17 AM
dumpster84
Apr 30, 2016 06:03 AM
user 82300
Sep 3, 2015 07:34 AM
priest16
15
Aug 6, 2015 07:43 AM
mikeyd6789
Aug 4, 2015 11:51 AM
