Pre 84 Trucks 1st gen pickups
Battery
Old Nov 21, 2011 | 09:36 PM
the big d's Avatar
Battery
What is the factory size as well as the requirement for cranking and cold cranking amps for a 79 Truck? I am suspecting when my battery box was replaced, that someone put in the wrong battery.
Old Nov 21, 2011 | 09:45 PM
Black_1985_SR5's Avatar
An optima yellow top
Old Nov 24, 2011 | 01:52 PM
Gov't Mule's Avatar
http://shop.advanceautoparts.com/web...RPBATTAM2_____
AutoCraft Silver from Advance Auto...last one I had in my yota lasted EIGHT years...just replaced it with another just like it.
Old Nov 24, 2011 | 04:08 PM
ThatGuy1295's Avatar
X2
Im not sure what the stock amps were supposed to be, but I'm sure an optima is more.
And having more cranking amps is what you want.
My yellow top's is goin on 6 years.
Old Nov 24, 2011 | 04:11 PM
I run dual yellows in the wheeler. Parellel configuration with no isolator. That doubles the cranking amps and amp hour capacity but not the voltage. Winches further and faster, and starts like its 70 degrees when its actually 30 degrees.
Old Nov 24, 2011 | 09:35 PM
the big d's Avatar
The battery is a group 58, which is like 650 cca. It cranks the truck ok. Its a budget dd, so no extra money is being put into it unless I can wedge the group 65 I have sitting on the shelf into it. Thanks for the input.
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
Gone Fission
Oct 7, 2015 12:42 PM
mreagen
Oct 5, 2015 04:27 PM
JPV
Sep 28, 2015 03:15 PM
