Pre 84 Trucks 1st gen pickups
83 pickup WONT START??
Old Jan 22, 2012 | 07:57 PM
jguap's Avatar
hi i just bought a 83 toyota pickup, 2wd, carb engine and i put new oil, oil filter, spark plugs. I know it needs a tune up because it has been sitting over in riverside, ca and looks like it needs work. Sometimes when im driving the idle will get stuck and hi rev until i give it some gas for the idle to go down. Im thinking it might need an idle adjustment (not sure how to do that, never dealt with carb engines)
and 2nd thing is, now it wont start and will die on me when im driving. It sounds like it wants to start, it will make noise like it wants to, but wont. The battery seems to work because lights are coming on and in and out of truck but wont turn over. Any suggestions guys??
also if anyone has a right front fender and bumper please let me know, im in ORANGE COUNTY, CA
Old Jan 22, 2012 | 08:41 PM
ROCK LIZARD's Avatar
If you have any mechanical ability get a Factory Service Manual and start at the beginning to get your truck running. If you have no mechanical ability, find a friend or good mechanic who knows old yotas (22R engine with carb) and get it running. Might need a carb rebuild or just clean fuel if it has been sitting for a long time.
Just because your lights come on doesn't mean your battery has enought amps to start the engine. Have the battery load tested if you don't know how.
Good luck!
Old Jan 22, 2012 | 08:43 PM
1983Toyota's Avatar
either battery is pooched or alternator isn't charging properly. especially if it dies on you and then you jump start it and it runs then it'll be the alternator
Old Jan 22, 2012 | 08:46 PM
Yep, should have mentioned what 83Toyota said--check alternator in addition to battery.
Old Jan 23, 2012 | 10:34 AM
UPS's Avatar
UPS
Put a fuel filter on it then clean everything you can see under the hood and underneath the engine/trans. Can't hurt and you'll thank me later.
Crazychris1871
Jun 27, 2016 10:38 AM
bigblue82
10
Jul 6, 2015 08:27 AM
94 bikehauler
Jun 30, 2015 11:19 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
serenity03k64
Jun 27, 2015 07:59 AM
