Pre 84 Trucks 1st gen pickups
Factory posi?
Old Mar 1, 2012 | 08:44 PM
YotaBoy83's Avatar
Factory posi?
OKay so I was talking with this older guy today that said in the earlier models with the solid axles the front end had a posi in it from the factory please tell me if this is right or wrong. I have an 83 and am curious of whats in there. Any and all input would be great thanks.
Old Mar 1, 2012 | 08:49 PM
toyota4x4907's Avatar
No. Yota trucks and 4runners never got factory locker/LSD/what have you, until the Tacoma era- '96+.
Early Land Cruisers (FJ/BJ-60 and some earlier models) had cable actuated lockers. Then the FZJ-80s in the mid-'90s had the option of front and rear electric lockers.
BoredOutnJackdUp's Avatar
nah, hes high. pull the third and look in there?
Old Mar 1, 2012 | 08:50 PM
Dang beat me to it!
Old Mar 1, 2012 | 09:54 PM
YotaBoy83's Avatar
That's what I thought I just wanted to double check.
Old Mar 1, 2012 | 10:37 PM
waskillywabbit's Avatar
Just cause you are old doesn't mean you are right.
:wabbit2:
Old Mar 2, 2012 | 08:47 AM
moroza's Avatar
I thought some later SR5's (maybe only 2wd ones) did have rear LSD as an option? Never in the front, though.
Old Mar 2, 2012 | 08:50 AM
2003mikem's Avatar
You could buy it as a factory add on in the early 80s.
It did have to be ordered from japan..
I have a factory installed pre TRD LSD diff.
Old Mar 2, 2012 | 09:49 AM
YotaBoy83's Avatar
How would I know if I had it. Is there like some bin number or something. My truck was originally out of California if that helps.
Old Mar 2, 2012 | 09:57 AM
badattitude's Avatar
spin test,
raise both front tires and spin. if you have posi both will spin same direction.
Old Mar 2, 2012 | 02:28 PM
YotaBoy83's Avatar
I've done that test in he past and both fronts spun in the same direction and one rear spun should I put any load on the tires
Old Mar 2, 2012 | 09:10 PM
YotaBoy83's Avatar
Like should I put a load on any of the tires if that would help or just lift it and watch
Old Mar 3, 2012 | 03:45 AM
suncomb1's Avatar
1979-1983 Toyota US bound 4x4 trucks did not have Posi's installed in them from the factory on either front or rear differentials. In 1983 you could order rear Posi's through your Toyota dealer and these were clutch type Posi's under the TRD label. In Canada, some 1980-1983 Toyota 4x4 trucks had rear clutch type Pos's factory installed or available as an option (Slacker would probably know more about this). Special option / limited edition 1983 Toyota 4x4 trucks (rare) had clutch type Posi's factory installed in front and rear differentials. This is being submitted by some "Old Guy". Ha Ha!
Old Mar 3, 2012 | 09:46 AM
YotaBoy83's Avatar
How do I find out what I have without tearing apart the axle. Is there a vin# I'll have or how to test it
Old Mar 3, 2012 | 12:12 PM
suncomb1's Avatar
I have factory Posi's in front and rear but my VIN # does not indicate this. My original paperwork, that I received when I purchased my truck, does show them under the list of additional equipment and options. I am not sure if the spin test would show a clutch type Posi installation but then I am not a mechanic. Maybe someone else in the forum can provide that information or tell you what what type of test you need to perform.
Old Mar 3, 2012 | 12:25 PM
YotaBoy83's Avatar
Alright thanks I hope someone chimes in on what I can do
Old Mar 3, 2012 | 04:35 PM
slacker's Avatar
YES I do .. and in Canada .. there were absolutly NO factory lockers installed in ANY 79-83 trucks 2 or 4WD .. NONE!!
Old Mar 3, 2012 | 04:41 PM
YotaBoy83's Avatar
So is there a possibility I do or do not have something in my front end
Old Mar 3, 2012 | 06:12 PM
From Toyota. No.
In the 30 years your truck has been in existence has someone put something besides the factory diff in the front, possible.
:wabbit2:
Old Mar 3, 2012 | 06:33 PM
YotaBoy83's Avatar
I don't know maybe. My truck was originally out of California and was shipped up to Washington with the original owner on a aircraft carrier. I could ask the original owner as he is my neighbor.
