Pre 84 Trucks 1st gen pickups
Engine Coolant Disappearing
Old Apr 3, 2012 | 07:55 PM
83Toyota88's Avatar
Ok I am losing engine coolant somewhere I think. I havnt seen any noticable leaks, however several weeks back when I replaced the seal on the rear output of my transfer case a little bit of antifreeze looking liquid came out when I pulled the seal off. Is it possible for it to go back that far or something? Or is it maybe possible that the radiator was low and sucking up what it needs from the tank? I checked the radiator a few minutes ago and it was at the top so idk.
Old Apr 3, 2012 | 10:45 PM
Terrys87's Avatar
I cant see it making it that far back, but anything is possible. Have you checked to make sure it isnt coming out of the tail pipe. Had that to happen on a 22re ahwle back. head gasket. Hope that is the worse case scenario.
Those Preston flush kits like to leak after they get old. Do you have one of them installed?
Water pump weep hole leaking? Check all hose connections. I should of posted this from least to worse or bottom, but hope this gets you going in the right direction.
Old Apr 4, 2012 | 05:16 AM
83Toyota88's Avatar
Thanks for the tips. I will try to check that tonight.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Poncho0206
Jul 10, 2015 06:21 PM
