Pre 84 Trucks 1st gen pickups
Frame Issues
Old Dec 16, 2011 | 09:07 AM
ledzeppelin3270's Avatar
Frame Issues
I've got pretty bad rot on the curve of the frame right before it goes over the rear axle. Being almost completely unexperienced in frame work, what is the best way to repair this? I don't have the means to do a frame swap or something, but I can weld. Suggestions and pictures would be greatly appreciated. I'm afraid to go offroad with the current condition. Which SUCKS.
Old Dec 16, 2011 | 10:34 AM
skypilot's Avatar
If your going off-road only you can build a new frame rail or back-half the truck. Back-half'ing is routinely done on musclecars for this and to handle the abuse.
Old Dec 16, 2011 | 10:56 AM
Thing is, it's my daily driver.
Old Dec 16, 2011 | 01:37 PM
skypilot's Avatar
You're screwed. Get a MIG welder and make boxes around the bad section to help support it. Get POR15 (expensive) and treat he rusted metal as best you can before welding. It will add a lot of weight to do it this way but at least you can drive it.
At some point you will run out of solid metal to attach to, and then its game over.
Old Dec 16, 2011 | 02:17 PM
WD_40's Avatar
Search these boards. Many members have repaired some pretty bad frame rot. There is a wealth of good info and pictures here.
Old Dec 16, 2011 | 02:33 PM
wyoming9's Avatar
Red face
If you can weld you can fix it
just take your time pictures of yours would be good. no need to use more than 1/8"
if at all possible take the bed off it will make it easier.
if you have any questions if feel free to pm I have fixed quite a few of these
Terrys87's Avatar
Here is a good build by fierohink.
https://www.yotatech.com/forums/f116...s-pics-228184/
Doing a frame swap isnt as bad as you may think. If you can pull a motor you can swap a frame. Look in my 88 rebuild on post #88. Step by step instructions.
These are about your only 2 options or really pay out the nose to get someone to fix it for you. I ran into this myself and alot of welders wont touch your frame as it is a liability risk. If it breaks they could be liable.
Old Dec 16, 2011 | 08:15 PM
I'll probably end up doing a frame swap this spring when I build my metal flatbed. But I just need something sturdy to get me through this winter (at least, because here in WI Yotas of this vintage are few and far between, let alone a rust-free donor.)
Old Jan 31, 2012 | 10:29 AM
simonwiley's Avatar
I'm shooting in the dark by asking this... but is it the passenger side by the fuel tank? I'm getting the feeling that due to the proximity of the fuel tank from the frame, the trucks gathered debris and mud in between the tank and the frame causing the rust. Mine rotted out there as well, but luckily I caught it before it completely rotted away. My solution was to remove the bed and fuel tank, and completely box in the rotted section. Of course you want to clean away all the rust you can before plating the bad sections over... but it is (in my opinion) a lot easier then replacing the frame. I have paid more attention to making sure all the mud and crap are cleaned out between my tank and frame every time I get home from wheeling it.
Old Jan 31, 2012 | 10:48 AM
22repower's Avatar
Has anyone found a good way to clean all that crap?
Old Jan 31, 2012 | 11:06 AM
83Toyota88's Avatar
Can you post a bigger picture of your truck? None of the albums on your profile work and I would like to see a closer view of your flatbed.
Old Feb 3, 2012 | 06:54 AM
simonwiley's Avatar
Muratic Acid (spelling?) works really good to clean up rust. Make sure to dilute it with water and apply it (using a spray bottle) in a well ventilated area. Try not to get it on anything aluminum. It will eat it up. You can buy the acid by the gallon at farm supply and hardware stores... and its pretty cheap (about $10 a gallon). Once you spray the diluted acid on the rust areas, let it sit and do its magic for about 15 minutes and rinse it off (using garden hose) thoroughly. You can do it again if your not satisfied.
You can also use grinders or wire wheels to remove the rust.
Old Feb 3, 2012 | 08:03 AM
83Toyota88's Avatar
What type of mix? 50/50 or different ratio? Or is it on mentioned on the bottle?
Old Feb 3, 2012 | 11:01 AM
wyoming9's Avatar
Red face
Any welder who is scared your truck is going to break after you paid a fair amount of money is in the wrong trade!!
Then to fix it the correct way is most often beyond the means or budget unless you do it your self
Depending how bad it is a frame splice would be cheaper labor wise if in your area you have good used frames to be had.
Unlike in the great eastern salt belt.
Old Feb 3, 2012 | 03:56 PM
It's on both sides of the frame, right where it curves to go over the rear axle. I'll try to post some pictures of it tomorrow... and to 83Toyota88 I'll take some close-ups of the flatbed for you too.
Old Feb 8, 2012 | 04:49 PM
young buck
18
Aug 27, 2018 02:40 PM
gieselman
Mar 20, 2016 04:34 PM
Backcountry411
Jul 24, 2015 08:06 AM
yourrealdad
Jul 21, 2015 11:13 AM
