Pre 84 Trucks 1st gen pickups
steering and brake issue?
Old Dec 11, 2011 | 05:39 AM
ydopen's Avatar
I tried useing the search but couldnt find what i was looking for?
steering= the wheel has slack in it? i changed the center rack a few years ago, dont tell me i need a new steering box?
brakes= when stoping the first pump is soft to the floor but the second pump is stiff and stops fine?
Old Dec 11, 2011 | 07:12 AM
kdo58's Avatar
you dont need a new one just a new used steering box.
Old Dec 11, 2011 | 07:37 AM
waskillywabbit's Avatar
Could be lots of things on either one.
Anything in the steering system could be worn causing the slack.
Anythign in the braking system could be worn causing the soft pedal.
What have you checked?
:wabbit2:
Old Dec 11, 2011 | 10:41 AM
ydopen's Avatar
I havent checked anything yet cause i really dont know where to start
Old Dec 11, 2011 | 04:41 PM
swampfox's Avatar
The box may need adjusted ,there is a screw with a jam nut on top ,turn it a little at a time It is very easy to over adjust.
Old Dec 11, 2011 | 10:35 PM
ConSeann3ry's Avatar
are your tie rods good? center link good?
brakes bled right? sounds like the master cylinder might need a rebuild
swamp fox, I'd like to know more about adjusting that jamnut...what happens when it's over adjusted and how do you check if you're at the right setting.
Old Dec 13, 2011 | 03:20 PM
swampfox's Avatar
The way I set mine was to loosen the jam nut while holding the screw, then turn the screw clock wise an 1/8 of a turn and tighten the nut while holding the screw. Then try turning the steering wheel if it still has to much play repeat the steps above ,untill most of the play is gone.If you over adjust it will get hard to turn . You will need to play with the setting to get it right. It would be a good idea to check out the front end as suggested above for worn parts.
Old Dec 15, 2011 | 11:33 PM
Thanks for the advice swampfox, just replaced my tie rods and rebuilt my centerlink and there is still just a little play, this sounds like just the trick
Old Dec 18, 2011 | 09:10 AM
ydopen's Avatar
The brake issue was the master cylinder, swapped it out and its doin fine now, if i see a loss of fluid i will move further, I tightened the steering box adjuster a 1/4 of a turn and it seems a little better, i gotta get a pully for my powersteering tensioner and get it back goin before i can really feel it out
jasonty
41
Dec 23, 2018 01:00 PM
voiddweller
Jul 15, 2015 03:56 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
