Pre 84 Trucks 1st gen pickups
Brake Squeal..
Old Apr 2, 2012 | 03:32 PM
funcrazy1's Avatar
Brake Squeal..
Just did a front brake change on the old yota yesterday and they are still squealing but when changing the front brakes there was not anti squeal pads? Other yota 83 never had when I changed them so I factored that out. Does this mean I have my rear drums to do?
Old Apr 2, 2012 | 04:01 PM
BMcEL's Avatar
Subscribed.
My '80 4x2 has an intermittent brake squeal as well. I rebuilt the drums because it needed it and the squeal is still there. Front pads are not down to the wear indicators yet (which will squeal like mad when they come in contact with the rotors...check that first).
I haven't bothered looking into it further.
Old Apr 2, 2012 | 04:28 PM
James Woods's Avatar
Did you get new rotors or get the old ones machined? Rotors can sometimes get grooves in them and it will be like the grooves on a record when you step on the brakes it will play that squeel for you.
Also, if you have a lot of brake dust in your drums, that can make noise also, pull the drum off and clean them and along with the front rotors should take care of your noise.
Old Apr 3, 2012 | 06:33 AM
funcrazy1's Avatar
How do you pull the drums off? I've never touched drum brakes ever
Old Apr 3, 2012 | 06:35 AM
Take the wheels off and hit the drum a few times with a hammer, then try to pull it off as you spin it.
Old Apr 3, 2012 | 04:52 PM
funcrazy1's Avatar
So went to Schwabs today for a free brake check.. They said its my rear drum shoes squealing they are thin as a fingernail... So I went to O'Reaillys to ask for shoes but there is two different sizes... 10x 1-31/32 or 10x 2-3/16 brake shoes.. I don't know what ones to get it.
Old Apr 5, 2012 | 04:14 PM
funcrazy1's Avatar
So here is my problem !
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
