Pre 84 Trucks 1st gen pickups
Oil Magic Trick
Old Mar 3, 2012 | 05:34 PM
kawazx636's Avatar
Oil Magic Trick
...ok, so it's not the oil magic trick you were hoping for, but I got your attention didn't I?!
I have about 2-3 quarts of oil "disappearing" every 300 miles or so. I change the oil and within a few hundred miles my oil light comes on. I check the dipstick and no oil! I completely cleaned the undercarriage of the truck - no signs of leaks. No oil in the driveway where I park it. No smoke or burning oil smell coming from the exhaust. Even if it was burning oil, I highly doubt that 2-3 quarts in 300 miles could go unnoticed in my rearview.
My 83 pickup has a 22R (131,000 miles), desmogged with a Weber carb - breather filter on the front valve cover hole and PCV valve routed down to the EGR plate provided by weber. I use 10w-30 pennzoil high mileage.
The motor seems to be running great, but has a way of making oil disappear! I simply can't figure out where it is going and it's driving me nuts.
Any ideas??
Old Mar 3, 2012 | 05:57 PM
RBX's Avatar
RBX
No blue smoke huh? Does the oil, when you drain it change it, smell like gas? Sounds like blow by, but if you don't smell burning oil...
I have a breather on my valve cover, and it definitely makes the area around it wet, but not 3qts wet.
So if I read your post right, you ran your PCV valve to the egr? So it's dumping into your exhaust manifold? I like the idea, just never heard of doing it that way. I would think that routin it that way would pressurize the system, rather then running from the intake which is producing a vacuum.
Sorry I don't have any answer for you.
Old Mar 3, 2012 | 06:03 PM
waskillywabbit's Avatar
Someone is messing with you. Kill one of your friends and keep killing one at a time until the oil leak stops. Then you fixed it.
:wabbit2:
Old Mar 3, 2012 | 06:12 PM
rworegon's Avatar
^^^^lol wabbit. With no signs of loss, it seems possible a neighbor is borrowing some for his oil changes.
Has it eaten the 2-3 qts more than once?
Old Mar 3, 2012 | 06:40 PM
toyospearo's Avatar
Originally Posted by waskillywabbit
someone is messing with you. Kill one of your friends and keep killing one at a time until the oil leak stops. Then you fixed it.
:wabbit2:
ahahahahhah!
Old Mar 3, 2012 | 07:42 PM
kawazx636's Avatar
Well, my wife absolutely hates my truck so.....maybe I have my first suspect! LOL
RBX, the PCV valve is routed back to the EGR port on the intake manifold, not the exhaust. I may have mis-spoke.
I'm thinking that it could be blow by, but 2-3 quarts in 300 miles still seems alot.
Anyway of determining for sure if it is blow by? Wouldn't I notice oil coming directly out of my exhaust??
Old Mar 3, 2012 | 08:39 PM
ConSeann3ry's Avatar
take your oil cap off and see how much blowby you have
Old Mar 4, 2012 | 07:39 AM
rworegon's Avatar
It is for sure. Has it used this much oil more than once?
What do the spark plugs look like?
Old Mar 4, 2012 | 07:45 AM
kawazx636's Avatar
I bought the truck about a 1,000 miles ago. Spark plugs look good, and it's been losing oil like this since I bought it. It's weird though because
The motor is otherwise running really well. Should I seafoam it and then run some Bar's Leaks through it??
Old Mar 4, 2012 | 08:53 AM
ksti's Avatar
IMHO If you cant find any leaks right now, I think adding Bar's Leak will only create a new problem now or down the road. That stuff can clog it up even worse.
Old Mar 4, 2012 | 10:59 AM
kawazx636's Avatar
Looks like a rebuild is closer in my future than I thought huh?
I was planning on doing it in the fall, but I don't want to run any irrepairable damage to that motor.
okamikai
Apr 30, 2018 10:19 PM
shadowbirdie
Jul 21, 2015 10:38 PM
cars-guy
Jul 11, 2015 07:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
