View Full Version : Pre 84 Trucks
- Another Header Question 20R
- 81 5-speed trans
- 3 broken rings, 1 piston and spun bearings - Options?
- oddball on ebay, is this really something toyota sold?
- I am thinking about getting a 82 Toyota pickup 4x4
- 83 pickup fuel filter
- Straight Axle value
- Crank pulley bolt stripped - HELP
- Electrical issues
- Shifter Bushings or no Shifter Bushings
- new head or whole new engine
- troubles removing Oil Pump Drive Spline
- How do you adjust a weber carb?
- How to remove top bolt on Transfer Case
- 87 engine 2 80 tran
- 4wd not engaging w/1980
- Is this worth anywhere near 1K?
- sm 426 tranny?
- 20R short block
- 82 22r header/exhaust set up???
- motor building or replaceing need input.
- 85 axle in a 83?
- 83 toyota pickup with no heat
- Wheels and backspacing?
- head stuck on 22r
- New 81 Pickup, what maintence should be done?
- Anybody running 38's?
- swapping parts 1979 to 1983
- replaceing head 20r or 22r?
- Back firing?
- electrical problems dies while running
- Emergency help (opinions) needed
- Overheating problems
- 1983 Pickup Project
- Help with rebuilding a 22r
- any one need
- 22r carburetor?
- 1983 pickup floorboard
- 5speed from 94 2wd mounted to 20r?
- Charcoal canister full of gas?
- Mojave edition
- I can't find a '78 heater control valve
- 22RE swap for 79
- over heating 1982 22r
- 83 bad mileage / poor throttle response
- Question about rear springs
- fuel leak 22r
- clutch change?
- 22R/20R Hybrid Details?
- Bright Bue Lash
- 83 bed is HOLY not in the good way
- 1982 toyta trekker
- carb issues
- 83 toyota SR5 head gasket first day i own it
- new rims and tires on my 80
- Tunning a 22r carb
- two trucks 100$.... Is this a good deal?
- 1979 Main Jet Size ??
- Need help with 86 axle swap into 82
- Post pics of '78-down trucks here and links for info
- What size U-bolts are needed on a 1980 pu with 2" lift blocks?
- Fuel Gauge
- cab mounts for a 83
- for sale
- 83 4x4 Toyota Truck Starting Problem
- Short doors
- Lifting or Leveling my 83 Yota
- may have found a awesome deal on a 81?
- seats and tires for 82' pikcup
- 83 4x4 - $1,500.....Is this a good deal??
- 20R Air Intake Hose
- 83 5 spd in the south?
- 1980 Exhaust manifold heat shield question
- 20R Tach help
- 81 22r vers 86 22r
- 20R "preformance"
- 82 22r diesling
- s/b 350 in first gen starting.......now
- 1982 toy pickup stereo wiring diagram
- L50/52 + 20R = Bad News so far!
- gas pedal fix?
- Interior Restoration. Where/How to start
- tach stop?
- Sensor/Gauge Hook Ups
- New to the site
- Eliminating Vac Lines on 20R
- 1978 pickup 4 speed to a 5 speed swap?
- headbolts?
- Paint opinions
- Idle on 20r
- thinking of getting a 82 or 83, thoughts?
- 22r swap
- Excessive Oil Leak from 81 22R
- 5m-ge in '80 1st gen pickup?
- my 82 toy
- Wanted: 1st Gen Frame & Cab
- 20R/22R Questions
- do i have the right fuse box? pics included
- fellow 1st gen trucker's help a bro out !!
- Anybody running 38's?????
- What's the best muffler for 20R?
- 1970 Hilux
- Strange temp problem
- Clutch Questions!!
- 87 runner 22re over heating
- '82 22r vibrates on turning off
- tranny swap info?
- 5 spd tranny identification
- Help. '81 22r won't idle in the heat
- 22r head onto a 20r does anyone know?
- First Gen Cab on Second Gen Frame
- Gonna buy a 81 4X4 with a bad tranny
- adjustable drag link...is it neccesary?
- 82 5spd to 4spd swap
- Dual Tcases?
- Efi System For Sale Complete!
- 1980 truck electrical help
- 22r fuel injection conversion
- 20R/22R Hybridization
- saggy springs
- What are syncros?
- 33's @ 5.29's yay or nay
- 1978 Toyota pickup. I need AC!!!
- Original Tire Size
- what year is my 22r
- 488's and 35's
- help with lift kit
- 1980 toy not idleing
- rockstomper motor mounts
- Weber owners,was it worth it?
- 82 4x4 Pickup Parts
- 20r L52-hd Bonding
- just keep building,building,building
- why must you stumble,truck?
- 1979 Shortbox Fun!! Build Time!
- 20r gearing/tire performance questions
- 34's or 35's how much lift???
- 20R Clutch Conundrum!
- hi steer crossover steering
- 5VZ engine swap
- What Would You Pay?
- jacked up dizzy
- pic of my truck?
- motor mount help
- Carb Jets and Alitude
- Vaccum line diagrams+hg questions
- Toyota Truck 79-83 Color and Spec Chart
- 20R alternator wiring
- any original diesel owners?
- knockin???
- engine swap
- carb issues 22r
- just bought an '82 PU
- buying an 80 pickup
- well.(*&%&%#^(*!! steering linkages
- Question about leaf springs. Lifting an 81.
- V-8
- A long-shot queastion about seats
- 20R Timing: what hoses to disconnect?
- W56 5speed tranny swap.
- Charging question
- Links to other useful gen1 4x4 sites??
- Is it the power steering pump or a leak?
- Identify these wheels
- My 1980
- w56 in 1980
- what is needed to swap a 22re into my 83?
- My first post...
- 83 pickup with 22r eng blowin' the blues
- brake master cylinder question???
- sloppy shifter fix??
- security options??
- Engine Options
- Wheel Size?
- chrome air filter for 20r 2bbl
- 1979-80 clutch replacement???
- Leaf Spring Help
- 22r to 22re swap
- Which lubes for my truck?
- 5mge install on my 82 truck
- weber trouble
- Uh-oh, bad noise while in 4 wheel drive
- EPN Headbolts
- Will long bed fit short bed truck?
- Need help deciding on engine & tranny for my '82 pickup!
- early pickup info
- 18-rc motor
- post up your mall crawling pics and specs
- 1980 Prerunner in San Diego
- 1980 4x4 in San diego
- 82 Shifter Problem
- 4x2 tranny
- 22r Crank Sleeve
- Are 22r rod/main bearings different sizes?
- steering problem on my 82 pickup
- Timing chain guide broke...need cover
- 82 Toyota 4x4 w/Tranny issues - what's the best solution?
- sloppy shifter
- troubleshooting transfer case leak
- Why does my 80 20R engine shake
- 1982 Toyota 4x4 questions
- 1983 Toyota 4x4 truck question
- got my 82 pickup!
