Pre 84 Trucks 1st gen pickups
temperature gauge broke?
Old Jan 18, 2012 | 10:05 PM
funcrazy1's Avatar
So I have 1980 2wd yota and I will go to start the truck in the morning when its cold out and I turn the key once and the temperature gauge shoots to instantly hot.. Is this bad sending unit? How can I find the sending unit its a 20r engine. Please help me
edit----
Thanks guys Fixed the problem love knowing my temp now
Old Jan 18, 2012 | 10:08 PM
Terrys87's Avatar
I have fixed a couple of the sending units just by getting the green gunk off of it. I just use a green scrubby pad or brass wire brush.
Old Jan 18, 2012 | 10:23 PM
funcrazy1's Avatar
So it is a bad sending unit? Cause the needle goes straight to the top when warming the truck.. Also could this be the reason why I have bad gas mileage only getting 16-18 mpg 201miles on 11 gallon tank?
Old Jan 19, 2012 | 03:45 PM
peow130's Avatar
Well 16-18 is normal for a carbed 4 cyl motor. Your temp sender is probably junk. Toss it and buy a new one.
Old Jan 20, 2012 | 07:49 AM
funcrazy1's Avatar
okay well sender is easy fix right just unbolt it, bolt the new one and plug the wire back in correct?
Old Jan 20, 2012 | 12:43 PM
sixstringslut's Avatar
Dope the threads or you will be sorry.
Old Jan 20, 2012 | 03:02 PM
peow130's Avatar
And in case you don't understand that jargon:
Wrap the theads in teflon tape.
Old Jan 20, 2012 | 03:24 PM
funcrazy1's Avatar
so pretty much lock tight correct?
Old Jan 25, 2012 | 07:57 AM
UPS's Avatar
UPS
Hope you didn't use locktite. poew130 meant plumbers white teflon tape. I think plumbers putty or "pipe dope" would be better or maybe even dielectric grease so the sender can make contact with the engine block. The sending unit varies the amount of ground or resistance to ground to tell the gauge what the engine temp is. If there is no contact between it and the block, there's no "ground" or total resistance = a cold/hot engine depending on how that sensor is setup.
Old Jan 25, 2012 | 09:55 AM
funcrazy1's Avatar
Well i didn't use locktite I used Teflon tape
Old Jan 25, 2012 | 10:03 AM
87Toy22r's Avatar
Your wire is grounding out some where. It's touching a metal part!!
Old Jan 25, 2012 | 10:45 AM
CajunKenny's Avatar
I've heard that JB Weld is a good thread sealer.
Old Jan 25, 2012 | 02:14 PM
funcrazy1's Avatar
I have fixed this issue it works no bad ground just bad sensor
yoterr
Sep 15, 2015 03:47 PM
jacked_72
Sep 14, 2015 03:31 PM
imhousing
Sep 10, 2015 02:04 PM
anndel
Sep 10, 2015 08:50 AM
LucasF249
Sep 8, 2015 01:17 PM
