PDA
View Full Version : Pre 84 Trucks
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 1979 Hilux rn33 wiring
  2. Automatic trans????
  3. 83 Pickup - Drag Link Movement
  4. Recognize this seat material?
  5. Broken oil pan bolt
  6. Installing new manual window regulator problem
  7. 22r no conpression 3rd cylinder
  8. Iso metal chrome visor
  9. Help identifying mystery wires
  10. 83 Pickup Won't Stay Running
  11. Leak out of unknown tranny seal
  12. Motor swap 96 22re with auto into 83. 22r manual transmission both are pickups
  13. Clutch not Disengaging after Transmission Swap
  14. 1978 Toyota pickup radiator 2022
  15. 1981 Toyota Pickup slips out of 3rd
  16. Lowering blocks AND add a leaf?
  17. old man emu lift anti-inversion plates
  18. 4 sp &5sp Interchangeable?
  19. 1978 20R Pickup Wiring Diagrams PDF File - Covers '72 to '78
  20. Fuel reader not accurate
  21. Help me pass smog.
  22. Carb Issues
  23. 1979 20R CARB adjustment
  24. 1979 2dr SEAT replacement/swap
  25. NOS Beds?
  26. Starting 22R that's been sitting 10 years
  27. Signal Generator/Distributor Pickup Problems
  28. Second post!! 1983 Toyota
  29. 1980 20r Aisin Carb Vacuum Lines
  30. New here
  31. 1983 restoration help! shifter help!!
  32. Fuel Idle Solenoid Issue
  33. Leak in shifter shaft L43 Transmission
  34. E-Brake Light 1980 Hilux
  35. Looking for a solid bed for a 1980 swb truck.
  36. Paint or No Paint
  37. 1981 4x4 pickup long bed paint code
  38. Best Seat covers under $150 for an 82?
  39. 82 Heater Valve Leaking
  40. 77 Hilux 20R Help
  41. L-engine diesel injection pump
  42. L50 to L52 swap
  43. Help identifying this part?
  44. Brand New Fuel Tank
  45. Looking for Condenser Hose
  46. 1980 Ignition Wiring?
  47. New Here
  48. Shifter issue 80 2wd 5speed
  49. 1983 4X4 22R still over over heating no coolant loss.
  50. Gears MIA (5-speed manual transmission)
  51. 79-83 Fender Emblem removal
  52. Extremely slow starter.
  53. roof skin replacement
  54. Need block!!
  55. What wheels do and don't fit Tacoma brakes?
  56. New guy with intro and 1979 4x4 longbed pickup
  57. window and door rubber
  58. Replacement gaskets for 20R manual linkage?
  59. new to site
  60. Engine turns over no spark.
  61. Help with t tops on a pick up
  62. American Racing Wheels On 1st Gen 4X4?
  63. Pushrod leak? Change Master Cylinder?
  64. 1980 AC compressor brackets needed
  65. No rear running or marker lights
  66. Brake lights sticking
  67. Transfer case
  68. What trim level do I have?
  69. Shocks to tall?
  70. Any way to adjust camber?
  71. Leaking around windshield
  72. New member, 1983 Pickup
  73. Accelerator Cable 1979 4x4
  74. !980 Pickup Smog Fail
  75. Parking Brake Handle pushes itself out?
  76. Alternator connector
  77. 63" leaf swap on my 1983 trekker 1st gen 4x4
  78. How to Rebuild a L52, by Someone Who's Never Even Pulled an Engine Before
  79. Egr questions
  80. 20r valve cover baffle torque specs
  81. 79 4x4 - What's this part?
  82. ISO 1979-1983 Toyota Cab & Chassis Body Builders Guide
  83. 1983 Truck interior info needed
  84. low power/hesitation?
  85. 1981 Toyota pickup 4x4 long bed wiper issues.
  86. Rear window….
  87. 79 4x4 Complete
  88. 77 pickup 20r backfiring, stalling
  89. Anybody done a v8 in there 1st gen?
  90. 1980 mini charge system headache
  91. 1980 Toyota Pckup 20r Weber 32/36 Install Inquiry- Please HELP!
  92. 22R found with outrageous ignition advance -- distributor or timing chain?
  93. Forgot where this part goes
  94. “20” stamped on head
  95. L52 Transmission fill plug location
  96. Leaking transfer case question
  97. Identify this washer
  98. 1980 Pickup 4x4 22r not making power.
  99. Need help. Simple body or possibly suspension lift for a 1977 2wd
  100. Calculating my final drive ration/speedo correction
  101. coolant/washer patchups/replacement options?
  102. 22R A/C compressor wiring pics?
  103. More gas tank fun
  104. Who can be trusted to rebuild a 22R?
  105. best source for suspension parts?
  106. 81 pickup 22r 32/36 weber dgav install issues
  107. Trying to wire in a 22re coil into my first gen pickup
  108. Diesel Engine Swap Compatibility Question
  109. Cabin replacement for Toyota 1981?
  110. 1981 Toyota Pickup Gas Pedal Help
  111. Timing/Camshaft Pulley Question
  112. Need help figuring out an alternative battery mount (82)
  113. Opinions on Defenders versus Wrangler tires?
  114. 22R Carb cannot throttle up?
  115. Need 20R engine
  116. IFS steering box placement on '79
  117. Overheating help!
  118. 81 celica project
  119. Paint Touch up 1982 4x4 Pickup Beige/Creme
  120. Weber 32/36 DGAV-DGEV choke
  121. Weber carburetor with stock 22R stock air cleaner.
  122. 83 Carb Rebuild
  123. W50 Transmission Extension Housing Dust Shield Retainer Removal
  124. 82 Front End
  125. 1980 20r idles fine,engine dies when accelerated
  126. WTB: Looking for pre 84 bench!
  127. 1978 20R ignition igniter wiring.
  128. Pre 84 backspacing on wheels
  129. 82 Land Cruiser BJ44 wiring diagrams?
  130. 1981 pickup 4x4 fuel tank
  131. 1983 Toyota gas pedal
  132. 81 SR5 Black Edition Question
  133. What are we running for carbs?
  134. 1982 4x4 5- speed Pickup shifter knob is giving me trouble
  135. 1981 Toyota 2wd pickup
  136. 22R - Oil Pressure (warning light)
  137. Will 0mm offset wheels rub on my 82 Pickup?
  138. Re 79 Cab mounts:
  139. Good source for accurate pics of our trucks
  140. stock height measurement
  141. how to fix broken steering column cover??
  142. New owner, fluid changes.
  143. Help with seat color and pattern
  144. Transmission fluid change
  145. Rear sliding glass perimeter weather seal
  146. Need picture of factory front tow hook mount
  147. 1st post -1981 Headlamp replacement
  148. free heater fan motor speed resistor
  149. 83 grill emblem on 79-81 grill?
  150. A/C install guide / factory A/C manual - part # needed
  151. 93 Toyota window regulator mod for vent window
  152. 20R Truck sounds like a john deer.
  153. 22r Vacuum advancing too much?
  154. Interior paint matching
  155. Throttle linkage repair
  156. LCE Pro distributor issue on my 20R
  157. Interior upgrades
  158. Suspension
  159. Adapting an ‘82 bed to an ‘81 tailgate
  160. Anyone from Canada?
  161. Radiator for 78 Toyota chinook
  162. Help needed with vacuum lines
  163. AA doubler question
  164. kayak/lumber rack for 1980 toyota pickup?
  165. Recent Purchase 81 truck
  166. Janky timing parts
  167. Producer Gas Pickup is on its way
  168. Help for an old 82
  169. Trucks pulls to the right under breaking.
  170. 82-83 A/C switch
  171. Hard start long start.
  172. Seat Swap?
  173. Gasket on bottom of 20R intake
  174. 1979 Toyota 4x4
  175. Header Compatibility
  176. 1980 wiring help
  177. What am I getting myself into?
  178. Rear sliding glass weatherstripping
  179. Repairing my ‘82 bed
  180. 2WD Bellhousing support brackets?
  181. Seeking Headliner trim - 79 4x4:
  182. what parts interchange?
  183. WEBER in CALI (ik lame)
  184. Another Wiper related question for an 82
  185. Gas Tank Capacity
  186. Will it work 81 22r into a 86 22r pickup
  187. 1981 Toyota Performance Issues.
  188. Seeking Bed underside pics (79 4x4 longbed)
  189. 77 pickup-cannot find a radiator!!:(
  190. factory stock 22r pics
  191. Double cab
  192. Backfired through carb after head gasket replacement?
  193. 1979 Interior Color Options
  194. 1st gen with a snorkel
  195. Knock coming from chain, piston, or valve clatter?
  196. 20r reverse switch
  197. 22R Engine Refresh?
  198. 81 22r Plugs Cap rotor Wires
  199. 20R timing trouble
  200. Exterior paint color?
  201. 5" Lift
  202. 81 Pick up rear brakes stick
  203. 4wd vs 2wd front bumper for a 79-81
  204. Electric choke question
  205. Which grille emblem
  206. 1983 Blinker Relay LED transition- Wiring Help!
  207. 2 question- radiator hose & steering wheel
  208. Trim Package ZD41?
  209. softopper review
  210. Re-Smog my 81????
  211. Steering Column 1983 4WD
  212. bed side inner panels
  213. Intake manifold parts ID
  214. Speedometer cable length
  215. What Clutch for a 2wd W50
  216. 82 Windshield Washer Nozzle mod?
  217. ‘80 Toyota 4x4 - add power steering
  218. Fast Pro Ignition E6CD with E92 coil install
  219. Carburetor
  220. Steering Grinding / Play / Thunk in Wheel Turning
  221. 1980 Aisan carburetor rebuild
  222. 1983 frame question!
  223. Any Denso wiper alternatives for 82 that screw on?
  224. Cali 22r Emissions and Weber 32/36 Help (Newbie)
  225. New Here!
  226. Desperate Tailgate Needed
  227. 1981 SR5 chrome grill
  228. WTB Aftermarket header 1979 w/ 20r 2WD 4 speed
  229. Front Differential Flip
  230. Qs on 79 Longbed 4x4 Shocks & fuel hoses
  231. 1981 SR5 Features and Options????
  232. Electrical issues( headlights)
  233. Ignition timing off - could it be the cam shaft timing?
  234. Carburetor
  235. 82 pickup 4wd
  236. Revived 1980
  237. 1980 20r propane injected truck
  238. 1980 20r propane injected truck
  239. 79-83 window question
  240. Transmission speed gear
  241. 20r mechanical fuel pump thermostat routing
  242. Valve clearance before timing job
  243. Tuffy console
  244. Whats going on with this bed?
  245. General questions 82sr5 weber 22r/desmog
  246. Where is the tach?
  247. 1979 Toyota Pickup Radiator Replacement Specs/Help/Part number
  248. 79 Toyota pickup 4x4 question
  249. 1979 Toyota pickup electric fuel pump question
  250. 82 pickup with 88 22r
