View Full Version : Pre 84 Trucks
- Exhaust Manifold Gaskets Extras????
- My New Toy
- Fuel Pump Check valve?
- Need to know quick
- 1982 22r carb issues..
- 1981 oil pressure/ diagram
- OEM Fuel Pump
- 3rd Gen (89-95) Bed on a 1st Gen (79-83)?
- rolled my truck
- Looking for a SOFT ride
- problem after 20r cam,carb, and headgasket install.
- new trans/clutch... wont go in gear
- Throttle cable length?
- 22R alternator on a 20R regulator ?
- CA Smog hell - 17%02 Reading
- Weber 38 Carb Help
- Cheap 22r carb kit
- 1982 pickup dash panel climate control panel removal
- 22r 82 Toyota Pickup 4x4 engine jumps/sputters on acceleration..
- 22r 82 Toyota pickup 4x4 engine sputters and jumps
- 8" thirds
- EGR cooler...cooled with coolant or oil?
- Thinking about switching to 20w-50
- My First Project Truck
- oil pressure gauge question
- Rain? Running?
- Brakes!!
- 1980 problem question about part
- any interior/body parts interchangeable between 79-83 and 84-88?
- 20r modification
- confusing 1980 problem
- thrust washers caused my new rebuild to blow !!!
- 82 axel or locking hub problem?
- 22R Head: 1981-1984 vs 1985-1995 Differences?
- 1980 VIN Issue
- front leaf spring lift questions
- distributor ..differant vacc. advance
- new to picture uploads! '81 yota
- 82 l45 clutch issues.
- A/C Removal?
- Built a flatbed
- Early First Gen Carb Question
- Stupid Carb Question
- Fuel pressure regulator
- 22r starts fine cold, intermittent warm start problem
- 1980 power steering?
- Clicking noise from front axle
- Truck is running hot and has no power.
- Trail suspension info/help
- Gearing questions and my drive shaft won't go on.
- '82 Hilux intermittent stumbling
- mirrors
- electrical gremilin
- Got In a Wrech In The Yota
- brakes want build pressure with motor OFF???
- just got a 81 longbed...
- Drop in bed liner for my 82
- 1980 ac???
- Weber 32/36 too much air
- 1977 Toy
- charging issue???
- 22r CARB tune
- New Breaker Breaker owner
- Unique 20R clicking/ticking video
- How hot do you run?
- Steering problem fixed!
- 20r 22r hybrid
- tryin to find the right distributor
- need some help with leaf spring
- WEIRD experience with a WIX oil filter
- Steel Bumper Fabrication
- Tach Not Working
- coil wiring problem
- Rear wheel cylinder brake lines
- Best rebuild Kit?
- No wire connector for my trailer hitch?
- 82 22r headgasket choice
- Lurkys 80' North Idaho Style!
- At my wits end w/ a fuel issue
- New Guy
- westjohns possible beater, 83 dlx 4wd
- how to remove rhino liner?
- '74 with issues, need YotaTech gurus (w/pics)
- 1979 toyota 4x4 lifted
- 81 pickup multiple questions
- 76 pickup owner's manual
- '81 Pickup
- all-pro offroad flatbed kit
- Need Picture of 1st Gen AC
- my '82 hilux
- not using choke
- Interchangable parts??
- Mirror replacement idea
- 16 in. Rims on 1st gen trucks
- 2WD Bed vs. 4WD Bed differences?
- Need Help with 2rz swap in a 1980 pickup
- l43 tranny help!
- Kunckle rebulid question
- 1st Gen AC question
- Hybrid 20/22r header
- Should I buy?
- '81 DCOE's stalling out
- Front shocks for Rock crawler
- carb intake on 86 22re
- just got a 83 2wd long bed DIESEL! cant get it to start.
- 1981 toy 4x4 upgrades?
- Trekker conversion
- Engine Options/opinions
- Dual diaphragm booster doesn't fit
- 1980 toyota pickup 17,000 original miles what's it worth?
- To galvanize or not?
- Hard brake line inner diameter question
- timing question
- Vibration around 55 MPH
- to many amps
- Taking off the doors
- major problem with new part
- Rust hole and crack on frame in front of the rear shackle
- Shakle angle with OME lift opinions please
- Steering wheel spins when breaking
- Thinkin about a lift
- Where to buy stock replacement leaf springs
- A/C Help
- 1st gen plate steel bumper build.
- Radiator sending fluid to overflow
- Good Source For Weber 32/36 Carb?
- re tapping exhaust manifold holes
- need feedback on bearing journals
- Need help diagnosing power steering problem
- 1979-83 dash question
- Knocking after valve adjustment
- Attn 79-80 4WD owners: You can now have Bigger Brakes
- 22r 1982 clean
- Swaybar?
- Quick Release Door Pin Video
- 22r wont idle!!
- 78 Toyota Camper sitting for 3 years
- Power Steering Bracket
- Grinding coming from transmission when I letting off the throttle / downshifting
- Traction bar bushing
- Manual Hub Problem
- Gas pedal mods?
- 79 toyota dash help
- Bad Engine Mounts/Tranny Mounts, or..?
- 20R cutting out under 2000 rpm
- Brighter Gauge Lights?
- California Desmog and Weber Help
- 1983 SR5 Truck 22r Rebuild Help
- Loosing brake fluid
- Toyota 83 Custom Cab
- 79 gas gauge
- speratic engine prob.
- Transfer case output shaft
- 20r vs. 22r
- 1st Gen Radio Options
- Intermediate starting issues.
- New Member Just bought a 1983 Toyota Mojave 2wd LWB 1 Owner with window sticker
- GM Ignition module, still no spark
- Couple Random Questions
- Weber 32/36 lag in secondarys solutions?
- Rear Transfer Output Yoke Nut Backing Off
- transmission or engine squeal? knocking during turns too
- A couple steering questions (read plenty of threads)
- Blinker question
- New to me 1980
- Dash light help 1980
- This is a first..
- Rock defense bumber on an 83
- 22R distributor vacuum advance diaphragm nipple interference
- Brake upgrades
- Quiet muffler suggestions
- 1979 2WD PU 4 Spd 20R exhaust system Q
- Head gasket or? And what should I have checked?
- 1980 longbed lift opinions
- 20R 22R hybrid help
- Bucket seat ideas needed
- 1979 4x4
- Electric Fuel Pump?
- Turbo my 22r?
- '82 4WD High NOx Test Failure
- First (1st ) generation ( gen ) 22r one ( 1 ) wire alternator parts / install
- Hello, new to me 1st gen
- G52 leak
- 22R Motor Swap - 1985-95 in a 1983
- Front drive shaft options
- New stereo for the 83
- Rear Parking Brake Clips
- 83 frame help
- Weber 32/36 idle rough
- Frames?
- Does the Cat really matter?
- 5 speed swap into 1982 4x4
- Head / Block mating issues?
- My new (to me) 81
- trail gear vs RUF
- Oil Pan Change
- MY first Toyota 1980 4x4
- my 1980 4x4
- 82, no charge lamp relay? Lights on, charge fine
- 7" headlight replacements!?
- Ordering axle rebuild parts and tools.
- Bobbing a long bed
- VIN Locations and Decoding
- 1982 22r 4x4 wont start without starting fluid
- Tranny Grinds when I release the clutch
- 22r running hot as heck
- Stock axles with 33's and 4.7 t-case gears?
- Custom Gas Tanks?
- 1st gen with LANDCRUISER 80 rims
- Staring Issue
- 20R carb spacer/insulator
- 1982 pickup power steering
- 79 toyota 4x4 NOT CHARGING, new ALT & VR
- Bed dimensions
- New owner, several small problems/questions
- Weber Jet Question
- Brake lever conversion for early '80's 4x4s
- motor swap
- Bringing a '82 4wd pickup back to life.....
- Ideas for mounting 1st gen rock sliders
- Exhaust Gasket Install
- Timing chain problems HELP!!
- 78' toyota 20r distributer problems
- My New 1980 yota!!!!
- 20/22r misfire/sputter?
- Rear Hitch on an 80
- 83 bumper on 80??
- i have some problems.......79-no power
- Extended Fender Flares for 81
- w56-a/b into 1st gen truck help
- new 81 pickup 2wd
- wiper arm exchange??
- 1980 21r ?????
- Which transmissions are interchangeable
- 1980 with w56 trans..Tcase issue
- 1st Gen Bumper options??
- Weber 32/36 dgav-33b1
- Help! identify leftover part after rebuild
- 200k mile head gasket???
- Engine shut off after initial startup
- Front axle options, what would you do?!
- Spring bushings
- L43 4 speed shifter issue
- 82 4x4 build and rust repairs
- Gas tanks
- Starter "sticking?" on first start
- Replacing a 22R Rear Crank Shaft Seal
- charging issue
- Fuel Tank Sender Unit repair
- Can you identify these Intake Manifold sensors?
