22R distributor vacuum advance diaphragm nipple interference - YotaTech Forums
Pre 84 Trucks 1st gen pickups
LinkBack Thread Tools Search this Thread
Old 05-26-2012, 02:37 PM   #1
trevorthetrekker's Avatar
What is wrong with this picture?
My vacuum advance hose is routed underneath the distributor's diaphragm, so I need to have it tied to the diaphragm (which kinks it) so it doesn't sit on the belt. I tried moving the distributor gear one tooth so the distributor is at more of an angle, so there is more of a clearance, but that changes the timing so much that I can't get it to run right at any range of adjustment. Yes, I even tried moving one tooth in the other direction just to see, to no avail.
I've been using it like this for a while, and it's been fine. However I finally have my Weber 38 jetted and tuned correctly (so it can actually run without choke; gotta love having manual choke!), so she really wants to be more advanced. Any more advanced than I am now, and I'll be rubbing MORE rubber off the advance hose.
I have also tried taking off the screw which holds in the diaphragm, to try to rotate the unit, but it didn't seem like it wanted to go. I didn't want to break anything either.
I wish I could return it, but it was bought in July 2011.
All of the other pictures I see show the nipples coming out of the side towards the carburetor; where they should be. I represented this in the above picture with the orange lines.
Any thoughts?
Thanks!
trevorthetrekker is offline   Reply With Quote
Old 05-27-2012, 04:25 AM   #2
83pingpong's Avatar
Why don't you just replace the advance diaphragm? I mean, you can get one, but will it fit? What kind of distributor is that? I got a OEM style replacement myself recently (Beck/Arnley or BWD), and it has the two standard vacuum connectors. How about taking the advance unit off your old distributor?
83pingpong is offline   Reply With Quote
1985 22r pickup, no spark but engine cranks sandyota 84-85 Trucks & 4Runners 12 04-30-2017 06:37 PM
CODE issue. SOS HELP! raptor510 86-95 Trucks & 4Runners 19 02-17-2017 07:11 AM
Code 25 issues raptor510 86-95 Trucks & 4Runners 18 08-19-2015 02:15 PM
22r new motor? cars-guy Pre 84 Trucks 4 07-27-2015 02:40 PM
Alternator swap, keeping it all Toyota. 80Truck Pre 84 Trucks 8 07-24-2015 03:12 PM
Tags
22r, 38, 87, 91, advance, diaphragm, distributor, fine, interference, lines, routing, run, toyota, tune, vacuum, weber
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
