Pre 84 Trucks 1st gen pickups
Built a flatbed
Old Aug 29, 2012 | 01:22 PM
Rickstwowheels's Avatar
Built a flatbed
I got tired of trying to find a tailgate for my truck and so I pulled the bed off and bought a welder and some metal. (pictures below)
I still need to do something with the exhaust, it is too loud. I have not done anything yet because I have to decide whether to go stock or buy a header. The PO built a pretty hot 22 hybrid then stuck a stock header on there. Also my wife is quitting her job and going back to school, so money is about to be tight! Other than that I just need to figure a way of controlling hot water to the heater core. There is no valve installed at this time, the control in the dash is attached to... nothing.
Here it is, since this picture I welded on some D rings along the side. I am thinking about a roll bar too.
Old Aug 29, 2012 | 01:40 PM
TylerH's Avatar
I really really like this, Great job! The cops might hassle you about mudflaps.
Old Aug 29, 2012 | 02:14 PM
85toy's Avatar
looks good but you should really rethink that hitch set up.
Old Aug 29, 2012 | 03:07 PM
Logan81Pickup's Avatar
I agree, that hitch will pull itself right off if you do any sort of pulling with it. I think a piece of tubing or two going diagonally to the crossmember would make it alot more sturdy.
Old Aug 29, 2012 | 03:30 PM
1980yota's Avatar
That looks cool! thanking of doing this to mine becuase the bed is about gone!lol What size tube and plate did you use? And thickness on the plate?
Thanks
Old Aug 29, 2012 | 04:53 PM
racerflea's Avatar
u might wanna get some square tubing to make some short bed rails
Old Aug 29, 2012 | 05:22 PM
I think I might try making something like this, except a little longer to carry my dirtbike, and with metal loops on it for tie downs. Then paint it black and rhino line the floor.
Edit: How wide did you make the main rectangle? And it looks like you used 3x2 tubing for most of the frame, is this correct?
Edit2: Did you seriously just "buy" a welder and start making that? Because those welds don't look like n00b work. I assume you had some previous experience?
Old Aug 29, 2012 | 05:36 PM
toyota4x4907's Avatar
Looks awesome. Im just curious why you didnt build it over the tires?
Old Aug 29, 2012 | 05:54 PM
Slow Mo's Avatar
I like it, defiantly need some fenders or something for the tires though.
Old Aug 29, 2012 | 08:19 PM
dropzone's Avatar
Fossilized
X33 on the tire coverage and reinforcing that 'hitch.
Gonna need corner clearance lights too...finish up the welds on the two front sides and close up the corner left hole on the diagonal(upper).
Off to a good start. Headache rack or tie downs in the future
Old Sep 2, 2012 | 08:39 AM
lilyota1's Avatar
Wow, when i took my truck bed off to cut out rust, i really debated this then decided no, it looks great tho, not massive or overwhelming, its perfect
Old Sep 3, 2012 | 03:26 AM
"x33". LOL yeah, everybody has a comment huh? To all with comments about the hitch, welds ect... I realize my post makes it sound like I was done perhaps. However, I have several things to do. Like finishing my welding on the plate and other parts, I'm thinking about adding a roll bar, and I haven't braced the hitch because I think I am going to shorten it some first.
Old Sep 3, 2012 | 03:31 AM
Thanks, I thought so too. And, that is really my only answer to the questions about why I built it the way I did. I saw a picture of one like this online and liked the look, so I built it this way.
Old Sep 3, 2012 | 03:34 AM
Thanks
I don't remember the thickness of the plate, the tube is 2x3"
Old Sep 3, 2012 | 06:33 PM
1980yota's Avatar
whats size ftxft was the plate i can only find 4x8
thanks
Old Sep 3, 2012 | 06:55 PM
It was 4x8. I cut the length but it is still four feet wide.
Old Sep 3, 2012 | 07:57 PM
1980yota's Avatar
Oh ok well now i know what a sheet of 4x8 will look like thanks Helped me alot
Old Sep 7, 2012 | 08:21 PM
AP4CHE's Avatar
Looks like you'd be able to break your own rear window if a rock decided to come loose at the right time. My friend had that happen to his truck from a fenderless trailer and chunky tires.
Old Aug 10, 2013 | 06:45 PM
83pickup-man's Avatar
looks awesome. im looking to make a flatbed that can be a flatbed, or bolt something to it if you need some sides.
ashamsuddin
17
Jul 22, 2024 03:59 AM
I8URSVT
Jan 15, 2016 07:25 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
tylermx71
Sep 29, 2015 08:49 PM
Toys4parts
Sep 26, 2015 01:56 PM
