Pre 84 Trucks 1st gen pickups
1980 power steering?
Old Aug 26, 2012 | 06:01 PM
rolltide81's Avatar
hey i got a 1980 4x4 20r .no power steering .i want to add power steering .how would i go about doing this and what parts do i need?just need a idea of how to do this thanks yalll
Old Aug 26, 2012 | 06:23 PM
Old_ blue's Avatar
I believe u need a power steering box but maybe you can just tap the one you have already. Of course you need the pump,lines and all that bull as well. You could buy an aftermarket pump and all that but you can also go to junkyard and pull one off a 22r (79-85)? i haven't done the swap so you should get other imput from other sources. try searching. there is no electrical or vaccum lines for these pumps so it should just bolt up and work.
Old Aug 26, 2012 | 06:34 PM
rolltide81's Avatar
ive tried searching if anyone knows a site that might have it let me know ..where would this bolt up or would i have to make brackets ??actually i dont have a clue where to start haha
Old Aug 26, 2012 | 06:56 PM
Lons81's Avatar
When I put p/s on my 81 22R, I pulled the system from an 82. I got the steering box, pump, pressure line from pump to steering box, return line to reservoir, cooler lines/cooler tubing that mounts behind the grille, pump mounting bracket and belt tensioner. The only thing I didn't get was the crank pulley, as it is wider than stock pulley without p/s.
Old Aug 26, 2012 | 07:19 PM
kawazx636's Avatar
You need the power steering pump, pump bracket, power steering reservoir, return hose, high pressure hose and a longer belt. I recommend going to a junk yard or try eBay. Installation should only take about an hour if you know how to turn a wrench.
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
