Pre 84 Trucks 1st gen pickups
22r starts fine cold, intermittent warm start problem
Old Aug 26, 2012 | 06:48 PM
sick84runner's Avatar
I just picked up an 83 pickup that has been stored in a sea container for the past 12 years! I threw a battery in it and put the fuel lines into a 5 gallon gas can, cranked it over, no spark. I put an ignitor and coil from another 83 that I have on it and it started right up. Ran great for 10 minutes, I shut it off and tried to restart it, cranks over but no spark. I let it sit for 30+ mins and it starts right up. Then the next day I started it up and shut it off 6 times in a row. No problem... I'm pretty confused on this issue.. Anybody have any ideas?
Old Aug 26, 2012 | 06:50 PM
Also the day it restarted over and over I was jiggling the wires from the ign. Switch in the column.. Could've been a coincidence.. Idk.
Old Aug 26, 2012 | 07:11 PM
kawazx636's Avatar
Go through and check all of your grounds. I've had similar issues and I had a bad ground to the starter. Replaced the ground cable and works perfectly now.
On another note, I see you're from VA and you have another "83." Do you use it for spare parts? If so, do you by chance have a shortbed that you are looking to get rid of?? I'm in the process of rebuilding the motor on my 83 and a full restoration so I may end up having some spare parts lying around that you may be interested in.
Old Aug 26, 2012 | 07:21 PM
It cranks over everytime just not getting spark. I was wondering if the pickup In the dist. Could be getting hot or if I have week ign. Power or high resistance in the wire to the coil/ignitor causing it to get hot and not fire.
And yes I have a strait 83 4x4 shortbed but I'm not sure if I want to get rid of it. I've been thinking about restoring that truck then exocage and make it pretty but functional for anything... Let me think about the bed for a few days and I'll get back to you about it.
Old Aug 26, 2012 | 07:42 PM
kawazx636's Avatar
Have you checked the timing? Could be off a bit, but that wouldn't cause all of your problems. You may also be getting too much fuel since it will turn over 30 minutes later-could be getting flooded. Another problem you might be having is the coil wire may not be all the way seated in the ignition coil - double check that as well.
PM sent about the bed.
Old Aug 26, 2012 | 07:58 PM
Ok I'll check that tomorrow. I'm hoping to get it strait sometime this week. Thanks for the info.
zd92655
Mar 6, 2022 12:58 PM
91toybeater
Dec 27, 2015 07:46 PM
Sandman
Jul 23, 2015 08:15 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
