Pre 84 Trucks 1st gen pickups
Head / Block mating issues?
Old May 14, 2012 | 05:23 AM
dlkelley713's Avatar
Hey Folks,
I'm swapping to a 20R head, new header, exhaust, cam, blah blah. While fitting my header and exhaust, I sat my old head onto the block. I noticed that the head will rock left and right... tapped it with mallet to make sure dowels were seated... no change. So then I tried my newly milled 20R head, but the result was the same. The block and both heads seem to check out straight with a straight-edge (the pistons are preventing a complete block check, but what I can check appears flat. Still with no head gasket, I put my old head back on bolts into the old head and torqued (in the proper sequence) to 5-10 ft lbs. The head seemed to pull down fine, but when I loosened the bolts it came back up some...
This motor is in a toy RV, and the last thing I want is to blow a head gasket 300 miles from home next week. This is my first time into this engine.
BTW, this block is an 82 (dual row TC) , 20r head is late 70s...unsure of year.
Anyone had any similar experiences?
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
