Pre 84 Trucks 1st gen pickups
Kunckle rebulid question
Old Jul 21, 2012 | 04:09 PM
jastamjas's Avatar
I am using the rebuild kit from trail gear and everything went smooth until i got to the adjusting nut. I TQ them to spec and followed the fsm but when i put the pull scale on to check it, its way above what the fsm calls for. Has anyone ran into this before.
Old Jul 21, 2012 | 04:46 PM
Gov't Mule's Avatar
Yep....same thing happened to me when I rebuilt mine with the TG kit. I said screw it and just went with the FSM torque specs and ignored the fact that the pull scale readings were way over what they were "supposed" to be. Been running for over a year now with NO issues.
Old Jul 21, 2012 | 05:58 PM
jastamjas's Avatar
Ok thanks
Old Jul 21, 2012 | 06:22 PM
Teuf's Avatar
As in pinion nut?
Old Jul 21, 2012 | 07:41 PM
slacker's Avatar
Originally Posted by Teuf
As in pinion nut?
no hub nut ..
I have found some differances with grease apps.
factory specs are with "moly" grease , is this what your using ?
Old Jul 21, 2012 | 07:46 PM
Teuf's Avatar
Ok got it. I will rebuild mine soon and need knowledge. As in the 83 axle I have that will go into my 88 some day soon.
Old Jul 22, 2012 | 07:11 AM
jastamjas's Avatar
Yeah i used molly grease and followed the rebuild thread on here
I think i will just run it for about 50 miles and check it again i am hoping the bearings just need broken in
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
