Pre 84 Trucks 1st gen pickups
major problem with new part
Old Jul 2, 2012 | 02:39 PM
rolltide81's Avatar
hey i been havein speratic engine problems dieing and suddenly cutting in and out on the freeway tried a few differant things someone told me to replace the ignition pick-up assembly that goes from my ignition connects to 2 wires that run into my distributor so i replaced it and tryed drivein it and it wouldnt start at the gas station and barley made it home without dieing ...did i do somethin wrong or could it be a bad part ..please help its my wife daily driver ....1980 toyota 4x4 20r
Old Jul 2, 2012 | 03:12 PM
bone collector's Avatar
check battery connections. could be bouncing on and off the battery terminals as your bouncing down the road.
Old Jul 2, 2012 | 05:20 PM
85toy's Avatar
are you talking about the coil or igniter?
Old Jul 2, 2012 | 06:46 PM
myyota's Avatar
Ok, so you replaced the pick up coil in the distributor, did you set the air gap properly ?.
Old Jul 2, 2012 | 07:24 PM
Terrys87's Avatar
Check your fuel system out. There is an intank filter and a filter on the frame by the fuel tank that could be plugging as well.
Old Jul 2, 2012 | 07:47 PM
rolltide81's Avatar
air gap ?shoot i dunno i thought it was a no brainer .it just has 2 screws not slotted i didnt think there was much adjustment to it .i put thr old one bcack in .is the air gap between the new ignition deal i put in there and the metal part of the rotor ?(where the rotor has those little blades on it that hits the metal peice of the ignition pick up)because i noticed the new pick up i put in there looked like it had a bigger gap.how would you set that?
Old Jul 2, 2012 | 08:44 PM
dropzone's Avatar
Fossilized
Fuel filter on an '80 should be on the p/s inner fender well
Old Jul 2, 2012 | 08:56 PM
myyota's Avatar
On your 20r engine it may be preset, another words remove and replace and your good to go. I put a pick up coil on a 86-87 22RE and you have to set the gap.
Old Jul 3, 2012 | 02:27 PM
rolltide81's Avatar
i m at a loss
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
ptb12
Jul 5, 2015 01:49 PM
