Pre 84 Trucks 1st gen pickups
CA Smog hell - 17%02 Reading
Old Sep 15, 2012 | 08:57 AM
estysalinas's Avatar
Question CA Smog hell - 17%02 Reading
Hi All - new to the the forum, but glad to have found it. Purchased a 83 4wd Truck (22r) from a ranch for 300 bucks. Got it running and the thing is in decent shape for being abused the way it was!
Here is what has been done so far:
  • Rebuilt Carb
  • New dist cap, plugs, wires
  • New fuel filter, oil + filter, radiator hoses, wheel bearings, and other basic PM.
  • New Cat and muffler
  • Replaced all the gaskets in the exhaust (Engine --> manifold, Manifold-->pipe, Pipe--->Cat)
  • Helicoiled all the manifold studs back in place can torque to spec w/o a problem
  • Plugged some minor leaks in exhaust that where found with soap and attached shop vac (blowing not sucking). Found more small leaks on the new welds cat/muffler then on the old down pipe!
  • I think I have fixed just about every minor leak in the exhaust.
Runs pretty well but will not pass smog due to high O2 readings (around 17%). 17% is super high to me (CA min is 2% it think). I have to be missing something pretty big..I just can't figure out what! Appreciate any help!
Old Sep 15, 2012 | 10:32 AM
bryan34w's Avatar
You can always try the isopropyl alcohol in the gas tank trick.
Old Sep 15, 2012 | 10:50 AM
ksti's Avatar
Someone might be able to help better if you post up smog results.
Old Sep 15, 2012 | 11:12 AM
Wish I could, but they won't run a CA SMOG with an Oxygen Percentage greater then 2%. So all i know right now is i have a very high Oxygen %.
Old Sep 15, 2012 | 01:26 PM
bryan34w's Avatar
I just did the alcohol trick about a month ago, but my hydrocarbons were high. But I noticed my co2 went down to zero from whatever it was.
Old Sep 16, 2012 | 07:17 PM
MortalYota's Avatar
I had the same problem. I just put a weber carb on and its running alot cleaner. I'm goin to get it smogged this week ill let you know how it goes.
Old Sep 24, 2012 | 08:58 PM
Ok so here is a thought, is there any chance that smog pump is pushing too much air into the exhaust thus causing the high O2 reading???
Old Sep 30, 2012 | 09:10 PM
slow-mo's Avatar
Here's some good reading material regarding combustion chemicals (smog related) and how they relate to each other.
http://www.autoshop101.com/forms/h56.pdf
http://www.autoshop101.com/forms/h55.pdf
Since you did not post all of your smog readings, you'll have to figure out what-is-what.
Old Sep 30, 2012 | 09:15 PM
MortalYota's Avatar
Just passed smog with flying colors. Let me know what you have questions about I can answer them and take lots of pictures of my set up
PNWrider
Oct 30, 2015 08:14 AM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
coffey50
Jul 28, 2015 10:55 AM
timmJ
Jul 7, 2015 02:01 PM
