Pre 84 Trucks 1st gen pickups
GM Ignition module, still no spark
Old Jun 1, 2012 | 02:11 PM
Rickstwowheels's Avatar
I was driving along today and as I started up a hill, my truck started dieing(not all at once), and eventually stalled. When trying to restart it, it would not even try. I checked an I had fuel (fuel filter is full), so I read on the forum about the GM ignition module swap, and I did that, still no spark. I have power all the places there should be power, and I have checked and re-checked my wiring. Any ideas?
Old Jun 1, 2012 | 03:27 PM
Rollz79's Avatar
Sounds like to me your distributor is bad.
Old Jun 1, 2012 | 04:13 PM
Is there a way to test it, other than seeing that it turns? Which it does.
Old Jun 1, 2012 | 05:40 PM
tazz76's Avatar
If ur cap and button have corrison on them that might be the issue
Old Jun 2, 2012 | 03:12 AM
I checked, no corrosion in the cap.
Old Jun 2, 2012 | 06:39 AM
Yopar's Avatar
Make sure you have a good coil. Maybe put your wiring up here and have everyone make sure it's wired correctly. Just draw a picture of how you did it and scan it or something.
Old Jun 3, 2012 | 10:56 AM
tazz76's Avatar
I have had a coil slowly go out on me before if u have a spare that is good switch then out to c if it works
Old Jun 4, 2012 | 09:03 AM
swampfox's Avatar
It might be a bad or contaminated pickup in the dist
Old Jun 4, 2012 | 11:42 AM
I found a good coil combo in the junk the PO gave me. I took out the GM stuff and put it in and I am good... for now.
MadMax48
Mar 3, 2020 10:33 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
JHalcyonM
Sep 14, 2015 01:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
