GM Ignition module, still no spark
I was driving along today and as I started up a hill, my truck started dieing(not all at once), and eventually stalled. When trying to restart it, it would not even try. I checked an I had fuel (fuel filter is full), so I read on the forum about the GM ignition module swap, and I did that, still no spark. I have power all the places there should be power, and I have checked and re-checked my wiring. Any ideas?
Sounds like to me your distributor is bad.
Originally Posted by Rollz79
(Post 51925056)
If ur cap and button have corrison on them that might be the issue
Originally Posted by tazz76
(Post 51925106)
Make sure you have a good coil. Maybe put your wiring up here and have everyone make sure it's wired correctly. Just draw a picture of how you did it and scan it or something.
I have had a coil slowly go out on me before if u have a spare that is good switch then out to c if it works
It might be a bad or contaminated pickup in the dist
I found a good coil combo in the junk the PO gave me. I took out the GM stuff and put it in and I am good... for now.
