Pre 84 Trucks 1st gen pickups
electrical gremilin
Old Aug 22, 2012 | 06:04 PM
kj1074's Avatar
electrical gremilin
Hey guys I have an 81 pickup. Parking brake light on dash wont turn off when the hand brake is released. Wont pass inspection that way. I changed out the switch under the dash and no change, the light stays on. I pulled the dash out and could not get a test light to light on the back of the gauge cluster on the 2 same color wires coming off the switch! what gives!? Shouldnt it lite up cause the light is staying on? (i hope i dont have to buy a new gauge cluster, it looks old and worn out)
Please help, thanks!
Old Aug 22, 2012 | 08:46 PM
UPS's Avatar
UPS
I believe it is a ground switch, not power. Their is a tab on the P-brake rod that pushes on the switch, that makes it ground. You may need to test it with a continuity tester. You're testing for ground, not power...... if I'm right.
Old Aug 23, 2012 | 03:03 PM
kj1074's Avatar
well that was a pita, new switch and dash out. ended up just being low on brake fluid! its always the simplest answer! didnt know that light also doubles as low brake fluid indicator.
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 24, 2015 01:12 PM
xzen73x
Sep 14, 2015 03:00 AM
