Pre 84 Trucks 1st gen pickups
Tach Not Working
Old Aug 11, 2012 | 09:44 PM
MortalYota's Avatar
Tach Not Working
Hey guys my tach isnt working on my truck and I was wondering if there was a part that goes out that causes this problem or what?
Old Aug 12, 2012 | 08:32 AM
83Toyota88's Avatar
Check all your wiring connections?
Old Aug 12, 2012 | 11:25 AM
hambob's Avatar
check the harness in the engine compartment for rubbing. Mine wore through the insulation and was grounding the tach wire. After replacing the tach itself I found the trouble spot. I threw some tape on it and it works again. good luck
Old Aug 12, 2012 | 12:51 PM
suncomb1's Avatar
There is green connector with a black cap on it near the igniter. Remove the cap from the plug and connect a test tach to the plug. Start you engine to see if the test tach gets a reading. If you have no reading it is the ignitor unit that is the problem. If you get a reading it is a problem in the wiring harness or the Tach unit. Run a wire from the test plug connection directly to the Tach unit input terminal on the instrument panel. If the Tach works you have a grounded or broken wire. If the Tach does not work you have a bad Tach unit. Fine a replacment Tach or a speedometer shop that knows how to fix Toyota Tach units.
ashersullivan88yota
Jan 18, 2022 05:37 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
