Pre 84 Trucks 1st gen pickups
Weber 32/36 idle rough
Old May 15, 2012 | 02:52 PM
YotaBoy83's Avatar
Question Weber 32/36 idle rough
So I'm having a problem with my weber having a rough idle and having slight missing. But this only happens at idle no other time right after 1200rpm its smooth and doesn't miss that I know of. Any tips on what it could be.
new motor, rv cam, full exhaust, new plugs, wires, coil, cap, and rotor.
Old May 15, 2012 | 02:53 PM
gennro's Avatar
How is the weber attached to the intake manifold?
Old May 15, 2012 | 03:00 PM
YotaBoy83's Avatar
with the dual adapter plates, i've already fixed any leaks due to a horrible leak it wouldn't run when I first put my motor back together
Old May 15, 2012 | 03:05 PM
gennro's Avatar
Have you done your valve lash yet?
Old May 15, 2012 | 03:09 PM
YotaBoy83's Avatar
yes I have, There's probably about 1000 miles on the motor and I did my valves twice can't really even hear them
Old May 15, 2012 | 04:14 PM
YotaBoy83's Avatar
I swapped out my dizzy too because it had some wobble too. The cap my have some damage from previous dizzy but was only on there for about 20 minutes
Old May 15, 2012 | 09:24 PM
1980yota's Avatar
my carb does the same thing untill it get really good and warmed up then it kinda idles. does it just need to be rebuilt?
______________
1980 toyota 4x4 4spd warhog weber 32/36 carb
Old May 16, 2012 | 08:36 AM
YotaBoy83's Avatar
Mine does it just on random days really. I have had the carb apart and it looked brand new on the inside
kazuya2416
Apr 5, 2024 02:17 AM
Eggslinger
Jun 8, 2019 03:32 PM
user 82300
Sep 3, 2015 07:34 AM
mikeyd6789
Aug 4, 2015 11:51 AM
