PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Looking for a 1975 pickup?
  2. 82 Toyota Pickup Starting Problems
  3. 3rd Member Swap Question
  4. Has anyone found a solution for the Weber two piece adapter on a 20R?
  5. A/C ?s Fed and Ca differences
  6. is this worth buying?
  7. Weber Fuel Leak
  8. rough idle, stalls when warmed
  9. Transmission help!
  10. Super swamper TSL Radials
  11. OME Flex!
  12. Is my cam gear timing correct? (pic)
  13. flat bed, or bobed bed? 79 yota long bed
  14. door locks and ignition cylinder
  15. Nice 81 Pickup with Camper shell (ebay)
  16. Transmission swap question
  17. New Shocks
  18. Newbie 83 build advice
  19. Trim piece question
  20. Front driveshaft
  21. Heater back plate
  22. 1980 20R Ignition Advance problems
  23. 1978 pick up swap?
  24. Seat Belt Connector
  25. LCE Hedder Found + Exhaust system?
  26. Carb Upgrade
  27. Tailgate stickers or paint ??
  28. WARN 8274 - Anybody Running One?
  29. 81 Trekker, horn help
  30. Which Bumpers Will Fit My 1981 4WD Truck?
  31. Cold high idle wont drop drown
  32. Camper id
  33. Looking for Retor Resources in SoCal - the OC 1980
  34. 22r Weber 32/36 help
  35. Compatible Mirrors
  36. Old Hedman Hedder? ID needed
  37. I WILL PAY $20.00 to the first person that can correctly diagnose my starting issue!!
  38. Replacement Radiator
  39. headlight
  40. 82 22re fueling problem
  41. No Power Going Uphills
  42. How many square ft?
  43. 1979 Lowest Vin for sale?...
  44. Front driveshaft problem
  45. U bolts for mounting transmission
  46. Steering pulls on freeway
  47. Gas tank
  48. These things are COOL!.......
  49. factory first gen clock
  50. Usa standard gears
  51. Usa standard gears g or b?
  52. I am losing coolant from the back of my cyl. head
  53. Oil consumption in my 22R
  54. Help with miss fire?
  55. How many stock wheels for a 78?
  56. 82 22r hesitates throughout power band
  57. 32/36 weber electric choke
  58. uneven tire wear
  59. wasted money on tires
  60. Ignition switch replaced, key turns, no starry
  61. Weird miss problem
  62. Is this a correct electric fuel pump to use on my setup?
  63. Is this what i need to convert my 83 pick up from manual to power steering??
  64. 20r wont run after putting in new fuel
  65. california header
  66. 22r tear-down analysis
  67. wierd tailpipe sound
  68. 83 toyota "4in pro comp suspension lift"
  69. SR5 Gauges Size
  70. shake rattle and roll home for repairs....
  71. Propane on new 22r???
  72. 1st start remanufactured 22r
  73. 83...have $8k to play with what you suggest?
  74. 1" master really worth it?
  75. 1980 4x4 headlights inop, any suggestions ?
  76. 1983 sr5 4x4 looking for tlc?
  77. PU Roof-rack brainstorming
  78. Brake work, need advise. 1983
  79. You get what you pay for :/
  80. Stock muffler size/part number for a 79 4x4 s/b...
  81. My 81 4x4
  82. 20R carb fast idle cam issue
  83. Pics of 35" A/T 1st gens?
  84. Has anyone successfully rebuilt a stock 20R carb?
  85. 81 Trekker Help
  86. 22r knocking HELP PLEASE
  87. Buying an 83 After Sitting for a Year
  88. 82-83 timing chain question
  89. 1981 Short Bed Window Sticker
  90. new springs question
  91. bad fuel pump?
  92. Body graphic sticker kit....1979 4x4
  93. Merry christmas
  94. l52 tranny sawp help
  95. 1982 Pickup Clutch
  96. Windshiel Trim Removal
  97. Need Good Repair Resources!
  98. The best 22r motor swap upgrade for your gen 1 trucks.
  99. 81 Hilux SR5 odometer issue
  100. Missing connection?
  101. My Possessed 78 part 2
  102. Solid axle crowd, share you brake upgrades!
  103. Its baaaack...........
  104. '81 fuse box
  105. 83 22R rocker arm replacement
  106. Gm 1 wire or 3 wire... Help!!
  107. black stuff in exhaust
  108. 1977 garage kept long bed 2wd
  109. Broken locker or axle shaft?
  110. Help me remove my body lift: Seattle Area
  111. tdi first gen ?
  112. Clutch pedal in the floor and shifting is getting more difficult.
  113. tranny info. location.
  114. floor rust cab bolts
  115. How to turn Filter and T-Belt lights off on an 82?
  116. stupid question timing chain help
  117. 1980 Hilux 38k on Ebay
  118. 1980 toy tranny question
  119. Leaf spring eye bolts?
  120. 4 speed to 5 swap
  121. Trekker Trouble
  122. Everything needed to convert 22r to EFI?
  123. 82 22r head gasket what parts do you guys recomend
  124. HELP! Serious charging system issue!! 1980 4WD Pickup
  125. 1983 aftermarket heater!
  126. 79 pick up turn signals stop working if headlights or heater on for a long time
  127. 83 Brake Booster DD Upgrade Question
  128. need advice before head bolt up
  129. 1979 20R carburetor linkage issue (I think)
  130. Bolt in alternator with more amps?
  131. 82 22r egr removal question
  132. Gaskets on either side of carb spacer
  133. Replacing floorboards
  134. Tow capacity 83 Toyota 4x4 low end torque
  135. STOCK wrangler YJ springs on front of pickup.
  136. specifications of a Toyota Pickup pre 84
  137. 70' hi-lux, trouble finding parts..
  138. 82 22r installed webber carb now volt light stays on charges fine ??
  139. 82 Vac Alternator Replacement??
  140. 82 Vac Alternator Replacement??
  141. Surging brakes on an 83 longbed
  142. Weber Carb Choke issue...
  143. Wondering how 2 paint....
  144. cleaning water and oil ports
  145. Carburetor Trouble
  146. Post your wheels!!!!
  147. 83 4x4 crossmember bolt problems
  148. Draining fuel from a carb off the vehicle
  149. bad fuel pump
  150. wiper blades going nuts
  151. Gauge Pod Location - Feedback wanted
  152. Looking for info on this orange
  153. throttle linkage problems!
  154. SWB vs LWB Actual frame lengths.
  155. my new 79 swb toyota pickup
  156. Battery drain, I think it's the alternator
  157. Door Speakers
  158. Somethings missing I'm sure??? 1st gen truck dash
  159. Clutch affecting idle
  160. OH Oh. What the heck is this commin out of the diff!??!
  161. '82 Emissions Control (ECC dated '81) pin assignments
  162. wiring diagram 1981
  163. No Spark, Need Help!!
  164. New Yota Owner 79' tk 2WD
  165. IFS and V6 rear end swap
  166. Rebuilt engine burning oil
  167. shifter question
  168. major head job and timing chain
  169. 1983 toyota 22r overheating
  170. Hilux Limited edition
  171. Christmas came early....
  172. 79 Fuel pump relay/cutoff switch
  173. '81 Pickup Timing Chain Service - HELP!
  174. 4cyl Diesel High RPM anyone???
  175. Stock Collector To Headers!
  176. Removing the dashboard from a 1981 Pickup
  177. 1980 20r in a cold weather climate?
  178. Oil drain plug problem. Need advice
  179. help needed with 4x4 sensor wiring...
  180. 82 22R Refuses to Idle
  181. Resets on start up
  182. sr5 gauge cluster
  183. new marlin l52
  184. Rebuilding caliper?
  185. Hard Starting stock 22R
  186. Persistent front main seal oil leak
  187. Mysterious blow by?
  188. Convert braker braker to pickup normal cab
  189. tranny question
  190. I need source for grille retainer clips and something else for 82 pickup please!
  191. Hid or hella headlights.
  192. lockers for 82 toyota
  193. 82 toyota rough riding an sag in the front
  194. Master Bushing kit??? Whos the best
  195. Can I fit in a 1st gen cabin
  196. Stripped exhaust manifold stud
  197. Where does the vacuum advance connect?
  198. v6 pinion leaks
  199. 22r bucking/missfire help
  200. 1983 Toyota Pickup Headlight Problem (Please help!)
  201. Bought Trekker, now what
  202. How can I access this area so I can deal with some rust?
  203. 1981 intermittant idle
  204. Intermittent key buzzer 77 pickup (i used search)
  205. my possessed 78
  206. tacoma stepside bed
  207. my 1980 engine pin in block
  208. crank deflection
  209. tire size
  210. W50 Transmission Specifications and Tolerances
  211. 1976 auto trans harness to 77 manual trans harness
  212. tranny issues
  213. Chasing Head Bolt Threads
  214. Carb idle problems
  215. Oil pump installation and priming.
  216. Radio Fit
  217. How do I get to the fuel pump?
  218. PS leak srapyng bottom hood?
  219. Bad afterburn, vacuum fuel cut off?
  220. 80 toyota 4x4 proportioning valve
  221. 1982 SR5 Tape player
  222. 1982 Pickup Rear Proportioning Valve
  223. Valve cover swap??
  224. 1980 2wd custom cab dually to 4x4?
  225. 1982 Pickup 5" lift
  226. 82/22r Runs fine one moment an dies the next
  227. 1980 Pickup - Dodge 3.9 V6 Magnum Swap???
  228. New member with a "new" truck
  229. Different Carburetor Floats?
  230. new weber
  231. Will this bumper fit mine?
  232. 20r intake specs
  233. Where can I get a replacement choke for my 81 pickup?
  234. Body Lift Possible Problems
  235. 81 pickup 22r doesn't want to stay running
  236. Truck Insurance - Full Coverage
  237. Head Gasket
  238. Body Line Molding
  239. Smog change from cali to federal
  240. Engine Surging with accessories on. PLEASE HELP!!!
  241. 20r differances in de- smog
  242. Front driveline, normal, or bad?
  243. 4XI... HD motor Mounts, 1980 frame.
  244. [VIDEO] 83 4x4 22r project
  245. Oil pressure gauge sender location '83 22re - Did search
  246. Is THIS why Toyota stopped making the full floating rear axle?
  247. Stock furst gen tire size question.
  248. Bed Cover Options
  249. what tranny do i have?
  250. looking for OEM slave cylinder for 1980
