Pre 84 Trucks 1st gen pickups
1st start remanufactured 22r
Old Jan 9, 2014 | 06:26 PM
Ove's Avatar
Ove
Finished install today. Motor will start up but run rough and not idle up. No leaks on intake/carb. Motor is desmogged, only running vaccum advance and power brake lines. Timing is set @ 5 degrees w/vaccum lines plugged. Any ideas would be much appreciated. Thanks!
Old Jan 9, 2014 | 09:44 PM
jhearold's Avatar
If your desmogged are you running a weber?? Might check all your spark plugs are on the correct firing order. I can't remember off hand but I think it's 1342??
Old Jan 10, 2014 | 03:50 AM
Zeeker's Avatar
I believe the timing should be set to 0 for a 22R. I think a 22RE's timing is set to 5. I'd have to check. Hope this helps...
Old Jan 10, 2014 | 06:20 AM
Killgore Trout's Avatar
did you remember to put the little flat bolt at the top rear of the valve cover back in, to hold the throttle cable tight lol, i had to slide mine all the way over to get the right tension after my 20 to 22r swap. did you set the carb to base line settings to start? Reset tdc and restab dizzy.
could your valve lash be out of spec enough to cause it to barely run? any mods besides ditching the egr baloney?
Old Jan 10, 2014 | 08:58 AM
kawazx636's Avatar
Timing is right - should be 5* BTDC at 700-950 RPM with the advance pinched.
Sounds to me like you could have a carb issue. Start with baseline settings and go from there. Also make sure you don't have the timing 360* out - If it is then it would be backfiring through the intake. To fix this, remove the distributor at TDC, turn the crank one full turn and restab the distributor.
Another issue could be elevation; what elevation are you working at?
Old Jan 10, 2014 | 01:40 PM
Ove's Avatar
Ove
Appreciate all the suggestions..Will work with baseline carb settings, check valve lash. Firing order is correct. Runnig weber 32/36 carb w/intake. Keep you all posted.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
CJ94yota
Jul 3, 2015 10:14 PM
