Pre 84 Trucks 1st gen pickups
factory first gen clock
Old Jan 22, 2014 | 05:55 PM
catfish21's Avatar
Ok I just got me a factory clock for my truck on eBay but anyway I would love to get some help on how this thing hooks up, it seems to me these things are very rare and hard to come by. But my truck has the Sr5 package and I have the tape player above my radio as we speak and that's where the clock goes it takes the place of the tape player, but anyway I would love to hear if any of Yall have hooked one up or know anything about it thanks
[IMG][/IMG]
Old Jan 23, 2014 | 04:50 AM
81 Toyo's Avatar
Looks like you have the factory harness, should be a plug and play deal, find the schematic and look behind your dash, should be straightforward. Cool find....
Old Jan 23, 2014 | 06:56 AM
catfish21's Avatar
Yeah the harness is with it but who ever had it before put those snap in connectors on it and there isn't any plug just to plug in so Idk what to do I'll have to play around with it but if anyone has anymore info please let me know
Old Jan 24, 2014 | 04:36 PM
catfish21's Avatar
Bump...... Really would love to here from someone that has installed one of these are knows anything about how they hook up or if someone has a diagram of the radio that mite help me also
Old Jan 24, 2014 | 05:49 PM
dropzone's Avatar
Fossilized
you are gonna have to pull out the dash bezel to search for the harness connection
Old Jan 24, 2014 | 06:04 PM
Lons81's Avatar
From what can trace on my 81 wiring diagram, the clock is powered from the dome light fuse via a black/white wire. It also runs to the #5 pin on the instrument panel connector and also powers the courtesy light switch. Maybe that might help. I'll look at a couple more diagram, they may help or not.
Old Jan 24, 2014 | 06:09 PM
catfish21's Avatar
Yes please do cause I'm not very good with vehicle diagrams
Old Jan 25, 2014 | 09:04 AM
Lons81's Avatar
Can't tell from the pic, but what are the wire color codes, what appears to be 3 wires. We all will try to get you up and running, clock wise.
Old Jan 25, 2014 | 12:41 PM
catfish21's Avatar
It has a red a blue a green and orange it's four wires
Old Jan 27, 2014 | 07:41 AM
Lons81's Avatar
Are there any numbers on the back of the clock? If so, #4 (+) could go to the cigarette lighter fuse circuit and the #1 (-) goes to ground in the circuit. #2 and #3 appear to run the dome and tail light circuit You could probably test them from a 9V battery or the truck battery with a 15A fuse in line.
Old Jan 27, 2014 | 09:11 AM
Lons81's Avatar
Found more info that may help. It may work for you. If no numbers then go with the letter designator below
Pin 1(GND) = GND
Pin 2(LIGHTS) = L+
Pin 3(12v) = C+
Pin 4 (IGN) = D+
Ground is kinda obvious,
L is for lights (so you can dim it with the instrument panel control),
C means constant (kinda like a memory function),
D stands for display (if the key isn't in the ignition, the display won't show up)
From thread https://www.yotatech.com/forums/f116...or+1988+pickup
Old Jan 27, 2014 | 06:06 PM
catfish21's Avatar
So I'm not much of a wiring guro but do I just need to find them wires in the dash and splice them
Old Jan 27, 2014 | 06:27 PM
catfish21's Avatar
[IMG][/IMG]
I don't see anything that would allow me to identify anything
Old Jan 27, 2014 | 06:31 PM
catfish21's Avatar
[IMG][/IMG]
This is gonna be a challenge I don't think it will be hard to splice it in its gonna be a problem finding out how to identify the clock and I don't want to just plug crap up and blow it up lol
Old Jan 28, 2014 | 03:40 AM
83Toyota88's Avatar
Have you tested the clock to see if it even works? If so post a picture of it. I almost bid on this item when I saw it on ebay.
Old Jan 28, 2014 | 09:16 AM
catfish21's Avatar
I have no way to check it I don't want to just start checking stuff if I can't identify what wire is what I'm one play with it a little more and if I can't find anything out I'm gonna see if the dealer can help me out
Old Jan 28, 2014 | 11:12 AM
83Toyota88's Avatar
I looked around and I can't find any wiring diagrams. All I found was the clock was option from a 1983 accessories catalog from the dealer. If the dealer cant help with the wiring you will have to start guessing the wires.
Old Jan 28, 2014 | 01:13 PM
CAdot's Avatar
Old Jan 28, 2014 | 03:44 PM
catfish21's Avatar
That look clean man yeah there's really no way to take it apart without tearing it and I have a factory manual and I don't.see not one thing.for the.clock so who knows
Old Feb 23, 2014 | 07:59 AM
83Toyota88's Avatar
You ever get this installed?
