Pre 84 Trucks 1st gen pickups
Carb Upgrade
Old Feb 10, 2014 | 03:56 PM
RabbITB's Avatar
Carb Upgrade
just picked up an 81 2wd for my sister. Having trouble starting in the cold so i was about to buy a 32/36. My question is if anyone has done the manual choke opposed to the electric. This is the one i was looking into as i prefer a manual choke... http://www.carburetion.com/Weber/Dat...M&Model=PICKUP ... Opinions?
Old Feb 11, 2014 | 09:18 AM
enigmaT120's Avatar
Yep. Check out this thread:
https://www.yotatech.com/forums/f114...torial-264405/
Old Feb 11, 2014 | 12:05 PM
kawazx636's Avatar
I went manual on mine - I prefer a manual choke since it is less electronics to potentially fail. It's easy to do since you essentially only have to route the choke cable from inside the cab. I ran mine through an existing grommet in the firewall and zip tied it to the throttle cable so it stayed where it belongs. Obviously, my truck is in a thousand pieces right now, but the only time I needed to use the choke was when it got cold out - never had to use it during the summer.
Old Feb 11, 2014 | 03:17 PM
RabbITB's Avatar
Thanks for the responses! Weber with manual choke on the way! Also i wanted to point out to others that the redline kits from LCE are alot more expensive than Carbs Unlimited... I use Carburation (Carbs Unlimited) for all my VW Carb stuff and they are great.
-Thanks
Old Feb 11, 2014 | 05:09 PM
83Toyota88's Avatar
-Thanks
Thanks for the heads up on that website.
kawazx636
Oct 6, 2021 03:03 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
4runnerFireman
Sep 29, 2015 06:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
