Pre 84 Trucks 1st gen pickups
need advice before head bolt up
Old Nov 30, 2013 | 10:15 AM
catfish21's Avatar
Ok I have got all the timing cover on and oil pan and before I put my head on I wanted to put a light coat of oil in the cylinders well I rotated the crank bolt while holding up on the cam sprocket and when it rotated back the timing marks are off now and I know for a fact that they were right when I put everything back on and it seems like everytime I turn the bolt to tdc the chain is in a new position. I'm so upset right now and I really don't know what to do so any advice would help thanks
Old Nov 30, 2013 | 10:43 AM
HighLux's Avatar
They dont line up every turn....roll her over a few more times....they will line back up.
You're good. Its cool.
Old Nov 30, 2013 | 10:58 AM
SCToy's Avatar
Exactly, i had that same feeling. They only line up
Every so often.
Old Nov 30, 2013 | 11:57 AM
catfish21's Avatar
Well I just wanted to know this is my first time doing a big job start up will be tomorrow morning
Old Nov 30, 2013 | 12:08 PM
HighLux's Avatar
You will get through it...its gonna run great. Confidence will soar. Stage 2 toyota fever will begin. May result in more toyotas.
Old Nov 30, 2013 | 12:13 PM
catfish21's Avatar
You can check some pics on my other thread and thank you a lot for all the help and encouragement
Old Nov 30, 2013 | 12:39 PM
kawazx636's Avatar
I believe they line up every 16 turns of the crank. The bottom sprocket has 18 teeth, the top sprocket has 36 teeth and the chain has 96 links. To get the chain to line up perfectly again you need 288 links which divides by 36 evenly 8 times. Then multiply that by 2 (since your crank turns twice to turn the cam once). If my math and philosphy are correct, it should take 16 turns to line up the bright link in the chain with the dimple mark in the cam. Pretty sure that is correct, but it doesn't really matter if the marks aren't lining up if it was initially set properly.
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
