Pre 84 Trucks 1st gen pickups
crank deflection
Old Sep 27, 2013 | 10:31 AM
Rowdydudeman's Avatar
crank deflection
anyone know what the max specs for crank deflection are? I discovered the source of this noise that has been plaguing me since i bought my pickemup. the damn thrush washers are worn enough to allow crank deflection, which in turn allows the crank to move enough to let my flywheel hit my starter ring BUT only when the driveline is in a bind. for example, i was able to replicate the noise yesterday by locking the hubs and turning in reverse with the wheel cut all the way to one side, atleast i finally figured it out! granted it's not a whole lot of movement, but jfc, it doesn't have to move very far before it starts interfering with normal/quiet operation.
I think i'm just going to throw new bearings on the entire rotating assembly along with seals and a new oil pump.
Old Sep 27, 2013 | 05:36 PM
found thrust clearance specs and limit. In case anyone needs the info, standard is .02-.22mm with a limit of .30mm
since mine flywheel is contacting the bendix, i think it's time to replace!
Old Sep 29, 2013 | 07:12 PM
discovered i'll be needing all new bearings too. the tin layer was pretty SMOOTHLY worn out, so ima swap em out while ive got it torn down. parts will be here tuesday along with mucho pictures for you whores that love a good fap to greasy "lower ends." XD
Old Oct 3, 2013 | 09:19 AM
Old Oct 3, 2013 | 09:20 AM
JonG85
Jan 18, 2023 04:31 PM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
gentry
Sep 28, 2015 06:16 AM
Corvoid
Sep 14, 2015 10:10 AM
