Pre 84 Trucks 1st gen pickups
Weird miss problem
Old Jan 17, 2014 | 06:08 PM
akehurst89's Avatar
Weird miss problem
Hey everyone I'm new to this site but need some help. I have a 1981 toy p/u with a 22r I just bought. It has a stumble when you shift gears and reapply gas. Timing is good, just did a tune up. Cap,rotor,wires and plugs. It idles smooth and drives great with continuous throttle. I just replaced the primary and secondary accelerator pumps but still has stumble? I just bought the truck last week and the previous owner had the same issue. Any idea or things to check?
Old Jan 17, 2014 | 06:29 PM
jahstrength's Avatar
Make sure your plug wires are on right order.
Old Jan 17, 2014 | 06:36 PM
akehurst89's Avatar
Somthing else I should have mentioned is the previous owner just did a head gasket on it. I set the timing at 8 degrees advanced at idle.
Old Jan 17, 2014 | 07:15 PM
kawazx636's Avatar
Should be 5* at 750-950rpm with the vacuum advance pinched
Old Jan 17, 2014 | 08:31 PM
dog walker's Avatar
Probably be more than just a miss! Maybe make sure that the plug wires are seated good at the distributor cap and plugs. Also check all of you're vacuum lines and vacuum switches. A faulty Vacuum switch will give you misses.
Old Jan 17, 2014 | 10:42 PM
If you have plugs 2 and 3 or 1 and 4 switched it will cause intermittent misses.
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
icentropy
Jul 14, 2015 10:23 AM
jon.r
Jul 11, 2015 03:34 PM
