Pre 84 Trucks 1st gen pickups
headlight
Old Jan 31, 2014 | 02:12 PM
highluxurynineteen8E's Avatar
headlight
Hello. I have a 1980 toyota long bed pickup. It has the SR20 motor, is two wheel drive
, and is an automatic. Anyhow, my passenger side headlight high beam works, but the low beam does not. Not thinking to check wires first, ( which i know nothing about) I bought a new headlight. I installed the new one, and nothing changed(except the old bulb, of course). So I'm thinking maybe a bad connection/ bad wire, etc. I don't know how to use any meters to check for bad connections, so any advice would be helpfull. Thanks.
Old Jan 31, 2014 | 03:02 PM
81 Toyo's Avatar
I would start with jiggling the connector around with the lights on to see if you have a bad connection at the bulb......electrical gemlins are sometime simple and othertimes a real pain to figure out..
Old Feb 1, 2014 | 03:30 AM
Thanks.
Old Feb 1, 2014 | 04:05 AM
Terrys87's Avatar
If the battery is secured well, I would suspect around the battery area. Otherwise it is just tracing out which wires that go to the low beam and looking for a break.
Old Feb 1, 2014 | 05:11 AM
dropzone's Avatar
Fossilized
it is a 20R
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
